Update #3818.
Update #3170.
Update #3199.
The fatal is internal indicator is redundant since the fatal source and
error code uniquely identify a fatal error. Keep the fatal user
extension is internal parameter for backward compatibility and set it to
false always.
Update #2825.
of this patch set.
* devnullfatal01/testcase.h, malloc02/init.c, malloc04/init.c,
malloctest/init.c, termios03/termios_testdriver_polled.c,
termios04/termios_testdriver_intr.c: Remove warnings.
PR 1632/testing
* Makefile.am, configure.ac: Make dedicated fatal error test for
/dev/null already registered. Using code from Bharath in new test
framework.
* devnullfatal01/.cvsignore, devnullfatal01/Makefile.am,
devnullfatal01/devnullfatal01.doc, devnullfatal01/devnullfatal01.scn,
devnullfatal01/testcase.h: New files.
