* | testsuites/libtests/[a-l]*: Change license to BSD-2 | Joel Sherrill | 2022-04-12 | 1 | -3/+22 |
| | | | | Updates #3053. | ||||
* | testsuites/libtests/[d-o]*: Change license to BSD-2 | Joel Sherrill | 2022-04-07 | 1 | -3/+22 |
* | sptests: Avoid include path magic | Sebastian Huber | 2019-11-12 | 1 | -1/+9 |
| | | | | Update #3818. | ||||
* | testsuite/libtests: Merged nested Makefile.am files into one Makefile.am | Chris Johns | 2018-04-10 | 1 | -24/+0 |
| | | | | | | This change is part of the testsuite Makefile.am reorganization. Update #3382 | ||||
* | tests: Remove obsolete TESTS_USE_PRINTK | Sebastian Huber | 2017-10-28 | 1 | -4/+0 |
| | | | | | Update #3170. Update #3199. | ||||
* | devnullfatal01/testcase.h: Avoid redefinition of TESTS_USE_PRINTK | Joel Sherrill | 2017-04-25 | 1 | -1/+3 |
* | score: Remove fatal is internal indicator | Sebastian Huber | 2016-12-09 | 1 | -1/+0 |
| | | | | | | | | | The fatal is internal indicator is redundant since the fatal source and error code uniquely identify a fatal error. Keep the fatal user extension is internal parameter for backward compatibility and set it to false always. Update #2825. | ||||
* | cpukit, testsuite: Add rtems_printf and rtems_printer support. | Chris Johns | 2016-05-25 | 1 | -1/+2 |
| | | | | | | | | | | | | | | | | | | | This change adds rtems_printf and related functions and wraps the RTEMS print plugin support into a user API. All references to the plugin are removed and replaced with the rtems_printer interface. Printk and related functions are made to return a valid number of characters formatted and output. The function attribute to check printf functions has been added to rtems_printf and printk. No changes to remove warrnings are part of this patch set. The testsuite has been moved over to the rtems_printer. The testsuite has a mix of rtems_printer access and direct print control via the tmacros.h header file. The support for begink/endk has been removed as it served no purpose and only confused the code base. The testsuite has not been refactored to use rtems_printf. This is future work. | ||||
* | tests/fatal: Fix test names | Sebastian Huber | 2014-03-31 | 1 | -1/+1 |
* | Change all references of rtems.com to rtems.org. | Chris Johns | 2014-03-21 | 2 | -2/+2 |
* | Remove All CVS Id Strings Possible Using a Script | Joel Sherrill | 2012-05-11 | 3 | -9/+0 |
* | Revert: Remove CVS Ids | Joel Sherrill | 2012-05-07 | 1 | -0/+5 |
| | | | | | See http://www.rtems.org/pipermail/rtems-devel/2012-May/001006.html for details. | ||||
* | Remove CVS-Ids. | Ralf Corsépius | 2012-05-04 | 1 | -5/+0 |
* | Remove all .cvsignore files. | Joel Sherrill | 2012-02-01 | 1 | -2/+0 |
* | 2011-12-08 Joel Sherrill <joel.sherrill@oarcorp.com> | Joel Sherrill | 2011-12-08 | 1 | -2/+1 |
| | | | | | | | | | | | | | | | | | | | | | | PR 1589/build * block01/Makefile.am, block02/Makefile.am, block03/Makefile.am, block04/Makefile.am, block05/Makefile.am, block06/Makefile.am, block07/Makefile.am, block08/Makefile.am, block09/Makefile.am, block10/Makefile.am, bspcmdline01/Makefile.am, cpuuse/Makefile.am, devfs01/Makefile.am, devfs02/Makefile.am, devfs03/Makefile.am, devfs04/Makefile.am, deviceio01/Makefile.am, devnullfatal01/Makefile.am, dumpbuf01/Makefile.am, ftp01/Makefile.am, gxx01/Makefile.am, heapwalk/Makefile.am, malloc02/Makefile.am, malloc03/Makefile.am, malloc04/Makefile.am, malloc05/Makefile.am, malloctest/Makefile.am, monitor/Makefile.am, monitor02/Makefile.am, mouse01/Makefile.am, putenvtest/Makefile.am, rtems++/Makefile.am, rtmonuse/Makefile.am, stackchk/Makefile.am, stackchk01/Makefile.am, stringto01/Makefile.am, tar01/Makefile.am, tar02/Makefile.am, tar03/Makefile.am, termios/Makefile.am, termios01/Makefile.am, termios02/Makefile.am, termios03/Makefile.am, termios04/Makefile.am, termios05/Makefile.am, termios06/Makefile.am, termios07/Makefile.am, termios08/Makefile.am, tztest/Makefile.am: Remove obsolete optional manager capability. | ||||
* | 2011-05-05 Joel Sherrill <joel.sherrill@oarcorp.com> | Joel Sherrill | 2011-05-05 | 1 | -0/+2 |
| | | | | | | * devnullfatal01/testcase.h, malloc02/init.c, malloc04/init.c, malloctest/init.c, termios03/termios_testdriver_polled.c, termios04/termios_testdriver_intr.c: Remove warnings. | ||||
* | 2010-07-27 Joel Sherrill <joel.sherrill@oarcorp.com> | Joel Sherrill | 2010-07-27 | 5 | -0/+88 |
PR 1632/testing * Makefile.am, configure.ac: Make dedicated fatal error test for /dev/null already registered. Using code from Bharath in new test framework. * devnullfatal01/.cvsignore, devnullfatal01/Makefile.am, devnullfatal01/devnullfatal01.doc, devnullfatal01/devnullfatal01.scn, devnullfatal01/testcase.h: New files. |
