path: root/testsuites/fstests/fstime/fstime.doc (follow)
* testsuites/fstests/*: Change license to BSD-2Joel Sherrill2022-04-121-3/+22
| | | | Updates #3053.
* Remove All CVS Id Strings Possible Using a ScriptJoel Sherrill2012-05-111-3/+0
* 2011-08-01 Xiang Cui <medivhc@gmail.com>Joel Sherrill2011-08-011-0/+28
* imfs_fslink/Makefile.am, imfs_fssymlink/Makefile.am, mimfs_fslink/Makefile.am, mimfs_fssymlink/Makefile.am, mrfs_fslink/Makefile.am, mrfs_fssymlink/Makefile.am, mrfs_support/fs_config.h: Correcting from previous commit of incorrect tarball. * fserror/fserror.doc, fserror/test.c, fspatheval/patheval.doc, fspatheval/test.c, fspermission/fspermission.doc, fspermission/test.c, fsrdwr/fsrdwr.doc, fsrdwr/init.c, fstime/fstime.doc, fstime/test.c, imfs_fserror/.cvsignore, imfs_fserror/Makefile.am, imfs_fslink/.cvsignore, imfs_fspatheval/.cvsignore, imfs_fspatheval/Makefile.am, imfs_fspermission/.cvsignore, imfs_fspermission/Makefile.am, imfs_fsrdwr/.cvsignore, imfs_fsrdwr/Makefile.am, imfs_fssymlink/.cvsignore, imfs_fstime/.cvsignore, imfs_fstime/Makefile.am, imfs_support/fs_supprot.h, mdosfs_fserror/.cvsignore, mdosfs_fserror/Makefile.am, mdosfs_fspatheval/.cvsignore, mdosfs_fspatheval/Makefile.am, mdosfs_fsrdwr/.cvsignore, mdosfs_fsrdwr/Makefile.am, mdosfs_fstime/.cvsignore, mdosfs_fstime/Makefile.am, mimfs_fserror/.cvsignore, mimfs_fserror/Makefile.am, mimfs_fslink/.cvsignore, mimfs_fspatheval/.cvsignore, mimfs_fspatheval/Makefile.am, mimfs_fspermission/.cvsignore, mimfs_fspermission/Makefile.am, mimfs_fsrdwr/.cvsignore, mimfs_fsrdwr/Makefile.am, mimfs_fssymlink/.cvsignore, mimfs_fstime/.cvsignore, mimfs_fstime/Makefile.am, mrfs_fserror/.cvsignore, mrfs_fserror/Makefile.am, mrfs_fslink/.cvsignore, mrfs_fspatheval/.cvsignore, mrfs_fspatheval/Makefile.am, mrfs_fspermission/.cvsignore, mrfs_fspermission/Makefile.am, mrfs_fsrdwr/.cvsignore, mrfs_fsrdwr/Makefile.am, mrfs_fssymlink/.cvsignore, mrfs_fstime/.cvsignore, mrfs_fstime/Makefile.am: New files.
