Updates #3053.
Updates #3053.
This avoids an extra include path.
Update #3818.
Update #3382
Fix file system names. Remove superfluous defines.
ftruncate() and open() with O_TRUNC shall upon successful completion
mark for update the st_ctime and st_mtime fields of the file.
truncate() shall upon successful completion, if the file size is
changed, mark for update the st_ctime and st_mtime fields of the file.
The POSIX standard "The Open Group Base Specifications Issue 7", IEEE
Std 1003.1, 2013 Edition says nothing about the behaviour of truncate()
if the file size remains unchanged.
Future directions of the standard may mandate the behaviour specified in
ftruncate():
http://austingroupbugs.net/view.php?id=489
The open path should update the times even if the truncate does not
change the size.
o Due to the usual integer propagation rules care must be taken in case
off_t is involved.
o Use the effective UID and GID consistently.
* fserror/test.c, fslink/test.c, fspatheval/test.c,
fspermission/test.c, fsrdwr/init.c, fssymlink/test.c,
fstime/test.c, support/fstest_support.c, support/ramdisk_support.c:
Explicitly include "pmacros.h".
* support/fstest.h: Don't include "pmacros.h".
Add config-header support.
* fserror/fserror.doc, fserror/test.c, fslink/fslink.doc,
fslink/test.c, fspatheval/patheval.doc, fspatheval/test.c,
fspermission/fspermission.doc, fspermission/test.c,
fsrdwr/fsrdwr.doc, fsrdwr/init.c, fssymlink/fssymlink.doc,
fssymlink/test.c, fstime/fstime.doc, fstime/test.c,
imfs_support/fs_config.h, imfs_support/fs_support.c,
imfs_support/fs_supprot.h, mdosfs_support/fs_config.h,
mdosfs_support/fs_support.c, mimfs_support/fs_config.h,
mimfs_support/fs_support.c, mrfs_support/fs_config.h,
mrfs_support/fs_support.c, support/fstest.h,
support/fstest_support.c, support/fstest_support.h,
support/ramdisk_support.c, support/ramdisk_support.h:
Fix CVS-Ids.
* configure.ac, fserror/test.c, fslink/test.c, fspermission/test.c,
fsrdwr/init.c, fssymlink/test.c, fstime/test.c,
mdosfs_support/fs_config.h, mdosfs_support/fs_support.c,
support/fstest.h, support/fstest_support.c,
support/ramdisk_support.c, support/ramdisk_support.h: Perform first
phase of clean up.
* imfs_fslink/Makefile.am, imfs_fssymlink/Makefile.am,
mimfs_fslink/Makefile.am, mimfs_fssymlink/Makefile.am,
mrfs_fslink/Makefile.am, mrfs_fssymlink/Makefile.am,
mrfs_support/fs_config.h: Correcting from previous commit of
incorrect tarball.
* fserror/fserror.doc, fserror/test.c, fspatheval/patheval.doc,
fspatheval/test.c, fspermission/fspermission.doc,
fspermission/test.c, fsrdwr/fsrdwr.doc, fsrdwr/init.c,
fstime/fstime.doc, fstime/test.c, imfs_fserror/.cvsignore,
imfs_fserror/Makefile.am, imfs_fslink/.cvsignore,
imfs_fspatheval/.cvsignore, imfs_fspatheval/Makefile.am,
imfs_fspermission/.cvsignore, imfs_fspermission/Makefile.am,
imfs_fsrdwr/.cvsignore, imfs_fsrdwr/Makefile.am,
imfs_fssymlink/.cvsignore, imfs_fstime/.cvsignore,
imfs_fstime/Makefile.am, imfs_support/fs_supprot.h,
mdosfs_fserror/.cvsignore, mdosfs_fserror/Makefile.am,
mdosfs_fspatheval/.cvsignore, mdosfs_fspatheval/Makefile.am,
mdosfs_fsrdwr/.cvsignore, mdosfs_fsrdwr/Makefile.am,
mdosfs_fstime/.cvsignore, mdosfs_fstime/Makefile.am,
mimfs_fserror/.cvsignore, mimfs_fserror/Makefile.am,
mimfs_fslink/.cvsignore, mimfs_fspatheval/.cvsignore,
mimfs_fspatheval/Makefile.am, mimfs_fspermission/.cvsignore,
mimfs_fspermission/Makefile.am, mimfs_fsrdwr/.cvsignore,
mimfs_fsrdwr/Makefile.am, mimfs_fssymlink/.cvsignore,
mimfs_fstime/.cvsignore, mimfs_fstime/Makefile.am,
mrfs_fserror/.cvsignore, mrfs_fserror/Makefile.am,
mrfs_fslink/.cvsignore, mrfs_fspatheval/.cvsignore,
mrfs_fspatheval/Makefile.am, mrfs_fspermission/.cvsignore,
mrfs_fspermission/Makefile.am, mrfs_fsrdwr/.cvsignore,
mrfs_fsrdwr/Makefile.am, mrfs_fssymlink/.cvsignore,
mrfs_fstime/.cvsignore, mrfs_fstime/Makefile.am: New files.
