* | spec: Remove empty reset from mvme3100 | Vijay Kumar Banerjee | 2023-08-01 | 1 | -1/+0 |
* | Update company name | Sebastian Huber | 2023-05-20 | 1 | -1/+1 |
| | | | | | The embedded brains GmbH & Co. KG is the legal successor of embedded brains GmbH. | ||||
* | spec/bsps: Do not install tm27.h | Chris Johns | 2022-08-22 | 1 | -1/+0 |
| | | | | Updates #4705 | ||||
* | build: Use common objects item for get memory | Sebastian Huber | 2021-11-30 | 1 | -1/+2 |
* | powerpc/shared/console: Make console baud rate configurable. | Peter Dufault | 2021-04-27 | 1 | -0/+2 |
| | | | | | | | | | | | The "powerpc/shared/console" code has the start-up console value fixed at 9600 baud. This changes the hard-wired constant "9600" in the code to the configuration setting "BSP_CONSOLE_BAUD" and adds configuration support in both the "waf" and the legacy configuration systems. Note that the VME BSPs beatnik, mvme3100, and mve5100 can be improved by adding a "mvmexxxx" BSP family. This configuration change, as well as future configuration changes, could then be made in a "grp.yml" file. | ||||
* | spec: Remove RTEMS_NETWORKING options | Vijay Kumar Banerjee | 2021-04-07 | 1 | -2/+0 |
| | | | | Update #3850 | ||||
* | bsps: Add default rtems_get_target_hash() | Sebastian Huber | 2021-02-26 | 1 | -0/+1 |
| | | | | Update #4267. | ||||
* | build: Alternative build system based on waf | Sebastian Huber | 2020-09-14 | 1 | -0/+90 |
Update #3818. |
