path: root/spec/build/bsps/powerpc/mpc55xxevb/obj.yml (follow)
* Update company nameSebastian Huber2023-05-201-1/+1
| | | | | The embedded brains GmbH & Co. KG is the legal successor of embedded brains GmbH.
* spec/bsps: Do not install tm27.hChris Johns2022-08-221-1/+0
| | | | Updates #4705
* libc: Optimize malloc() initializationSebastian Huber2021-11-301-0/+1
| | | | | | | | | | | | | | | | The BSPs provide memory for the separate C Program Heap initialization via _Memory_Get(). Most BSPs provide exactly one memory area. Only two BSPs provide more than one memory area (arm/altera-cyclone-v and bsps/powerpc/mpc55xxevb). Only if more than one memory area is provided, there is a need to use _Heap_Extend(). Provide two implementations to initialize the separate C Program Heap and let the BSP select one of the implementations based on the number of provided memory areas. This gets rid of a dependency on _Heap_Extend(). It also avoids dead code sections for most BSPs. Change licence to BSD-2-Clause according to file history. Update #3053.
* score: Optimize Workspace Handler initializationSebastian Huber2021-11-301-0/+1
| | | | | | | | | | | | The BSPs provide memory for the workspace initialization via _Memory_Get(). Most BSPs provide exactly one memory area. Only two BSPs provide more than one memory area (arm/altera-cyclone-v and bsps/powerpc/mpc55xxevb). Only if more than one memory area is provided, there is a need to use _Heap_Extend(). Provide two implementations to initialize the workspace handler and let the BSP select one of the implementations based on the number of provided memory areas. This gets rid of a dependency on _Heap_Extend(). It also avoids dead code sections for most BSPs.
* bsps: Add default rtems_get_target_hash()Sebastian Huber2021-02-261-0/+1
| | | | Update #4267.
* build: Alternative build system based on wafSebastian Huber2020-09-141-0/+97
Update #3818.
