path: root/spec/build/bsps/opttestoptflags.yml (follow)
* Update company nameSebastian Huber2023-05-201-1/+1
| | | | | The embedded brains GmbH & Co. KG is the legal successor of embedded brains GmbH.
* build: Use enabled by for defaultsSebastian Huber2023-01-171-2/+3
| | | | | | | | | | | | | | Merge the "default" and "default-by-variant" attributes. Use an "enabled-by" expression to select the default value based on the enabled set. This makes it possible to select default values depending on other options. For example you could choose memory settings based on whether RTEMS_SMP is enabled or disabled. The change was tested by comparing the output of ./waf bspdefaults before and after the change.
* build: Allow separate optimization flagsSebastian Huber2022-07-041-0/+18
Allow separate optimization flags for the BSP, cpukit, and tests. For example, the BSP and cpukit may be built without optimization if coverage instrumentation is enabled, however, the tests may still use optimization. Update #4670.
