brains GmbH.
This patch includes the spec/build options for the riscv kendrytek210
BSP variant. It includes options to allow the frdme310arty console
UART to be used on multiple BSPS, device tree options, memory
options, and other required options for the variant.
Updates #4876
Merge the "default" and "default-by-variant" attributes. Use an
"enabled-by" expression to select the default value based on the enabled
set. This makes it possible to select default values depending on other
options. For example you could choose memory settings based on whether
RTEMS_SMP is enabled or disabled.
The change was tested by comparing the output of
./waf bspdefaults
before and after the change.
Replace the variant patterns in the default-by-variant list with an
explicit list of matching BSPs.
./waf bspdefaults
Add dtb and dtb header path configurable build option
