Replace the BSP_CONSOLE_MINOR BSP option for the Xilinx Zynq BSPs with the new
BSP option ZYNQ_UART_KERNEL_IO_BASE_ADDR. Move the kernel I/O support to a
shared file.
The base addresses and IRQ numbers for UART 0 and 1 were interchanged.
Fix this and set BSP_CONSOLE_MINOR to 0 for this BSP family.
This patch adds basic support for the following boards:
xilinx_zynq_pynq - PYNQ Z1 / Z2
xilinx_zynq_microzed - MicroZed 7010 / 7020
xilinx_zynq_picozed - PicoZed 7010 / 7015 / 7020 / 7030
xilinx_zynq_zybo - ZYBO
xilinx_zynq_zybo_z7 - ZYBO Z7-10 / Z7-20
N.b. Arty Z7-20 is basically a PYNQ Z1 - different board
color and updated Eth PHY.
brains GmbH.
Merge the "default" and "default-by-variant" attributes. Use an
"enabled-by" expression to select the default value based on the enabled
set. This makes it possible to select default values depending on other
options. For example you could choose memory settings based on whether
RTEMS_SMP is enabled or disabled.
The change was tested by comparing the output of
./waf bspdefaults
before and after the change.
Prefix the BSP family name with "bsps/" to make it distinct to the BSP
variant names.
Update #4468.
- Optionally add support for 'default-by-family' to allow
option to be set by a family and so all related BSPs
Close #4468
The option for defining the console minor should be an integer, not a
boolean.
This adds a BSP family that runs on the Xilinx Ultrascale+ MPSOC
(ZynqMP) family of chips. It is configured to be usable on the Qemu
ZCU102 machine definition and should be almost trivially portable to
ZynqMP development boards and custom hardware. It is also configured to
be usable with libbsd.
