brains GmbH.
Merge the "default" and "default-by-variant" attributes. Use an
"enabled-by" expression to select the default value based on the enabled
set. This makes it possible to select default values depending on other
options. For example you could choose memory settings based on whether
RTEMS_SMP is enabled or disabled.
The change was tested by comparing the output of
./waf bspdefaults
before and after the change.
Allow separate optimization flags for the BSP, cpukit, and tests. For example,
the BSP and cpukit may be built without optimization if coverage
instrumentation is enabled, however, the tests may still use optimization.
Update #4670.
