path: root/spec/build/bsps/nios2/nios2_iss (follow)
* Update company nameSebastian Huber2023-05-203-3/+3
| | | | | The embedded brains GmbH & Co. KG is the legal successor of embedded brains GmbH.
* build: Use enabled by for defaultsSebastian Huber2023-01-171-3/+4
| | | | | | | | | | | | | | Merge the "default" and "default-by-variant" attributes. Use an "enabled-by" expression to select the default value based on the enabled set. This makes it possible to select default values depending on other options. For example you could choose memory settings based on whether RTEMS_SMP is enabled or disabled. The change was tested by comparing the output of ./waf bspdefaults before and after the change.
* spec/bsps: Do not install tm27.hChris Johns2022-08-221-1/+0
| | | | Updates #4705
* build: Use common objects item for get memorySebastian Huber2021-11-301-1/+2
* build: Merge default-by-family into by-variantSebastian Huber2021-08-181-1/+0
| | | | | | | Prefix the BSP family name with "bsps/" to make it distinct to the BSP variant names. Update #4468.
* build: Use BSP family for optionsChris Johns2021-07-151-0/+1
| | | | | | | - Optionally add support for 'default-by-family' to allow option to be set by a family and so all related BSPs Close #4468
* bsps: Add default rtems_get_target_hash()Sebastian Huber2021-02-261-0/+1
| | | | Update #4267.
* build: Alternative build system based on wafSebastian Huber2020-09-143-0/+81
Update #3818.
