* | Update company name | Sebastian Huber | 2023-05-20 | 1 | -1/+1 |
| | | | | | The embedded brains GmbH & Co. KG is the legal successor of embedded brains GmbH. | ||||
* | build: Allow separate optimization flags | Sebastian Huber | 2022-07-04 | 1 | -0/+8 |
| | | | | | | | | Allow separate optimization flags for the BSP, cpukit, and tests. For example, the BSP and cpukit may be built without optimization if coverage instrumentation is enabled, however, the tests may still use optimization. Update #4670. | ||||
* | build: Add option to customize the LINKFLAGS | Sebastian Huber | 2021-07-06 | 1 | -0/+2 |
* | build: Alternative build system based on waf | Sebastian Huber | 2020-09-14 | 1 | -0/+39 |
Update #3818. |
