This adds support for the STM32H750B-DK discovery kit. This kit includes
a built-in STLINKv3 debugger which provides a USB serial bridge for
USART3. USART1 is routed to the Arduino header and USART2 is routed to
the STMOD connector. This BSP reuses what would otherwise be duplicated
files from the stm32h747i-disco BSP. Note that system_stm32h7xx.c has
been imported from the STM repository with two minor changes wrapped
with #if __rtems__. This hardware has been tested with hello and ticker.
brains GmbH.
Merge the "default" and "default-by-variant" attributes. Use an
"enabled-by" expression to select the default value based on the enabled
set. This makes it possible to select default values depending on other
options. For example you could choose memory settings based on whether
RTEMS_SMP is enabled or disabled.
The change was tested by comparing the output of
./waf bspdefaults
before and after the change.
Use yaml.dump(data, default_flow_style=False, allow_unicode=True) with a
custom representer for integer default values to format all build items.
Prefix the BSP family name with "bsps/" to make it distinct to the BSP
variant names.
Update #4468.
- Optionally add support for 'default-by-family' to allow
option to be set by a family and so all related BSPs
Close #4468
Now using default pins
