This adds support for the STM32H750B-DK discovery kit. This kit includes
a built-in STLINKv3 debugger which provides a USB serial bridge for
USART3. USART1 is routed to the Arduino header and USART2 is routed to
the STMOD connector. This BSP reuses what would otherwise be duplicated
files from the stm32h747i-disco BSP. Note that system_stm32h7xx.c has
been imported from the STM repository with two minor changes wrapped
with #if __rtems__. This hardware has been tested with hello and ticker.
brains GmbH.
Merge the "default" and "default-by-variant" attributes. Use an
"enabled-by" expression to select the default value based on the enabled
set. This makes it possible to select default values depending on other
options. For example you could choose memory settings based on whether
RTEMS_SMP is enabled or disabled.
The change was tested by comparing the output of
./waf bspdefaults
before and after the change.
Replace the variant patterns in the default-by-variant list with an
explicit list of matching BSPs.
./waf bspdefaults
Use yaml.dump(data, default_flow_style=False, allow_unicode=True) with a
custom representer for integer default values to format all build items.
Nucleo does not have any SDRAM so default linkage to SDRAM does not make
any sense here.
Sponsored-By: Precidata
This patch adds stm32h747i-disco-m4 BSP variant and puts it in sync
with the stm32h747i-disco BSP variant hardware support. That means,
only USART 1, 2 and UART 8 are enabled. Also SDRAM 2 is set to 32MB,
SDRAM 1 size is set to 0.
This is minimalist configuration for the stm32h757i-eval-m4 BSP provided
here. The only general enhancement worth mention is a flash origin address
configuration which is needed for simplification as M4 core boots
from second flash bank which starts at 0x8100000 by default. The boot
address of the core may be changed by using STM32CubeProgrammer. If done
so then also BSP configuration needs to be changed accordingly.
As the BSP variant is running on M4 core, there is also more configuration
changes required here. E.g. boot core and ABI (compilation flags)
in comparison with stm32h757i-eval BSP. On the other hand, C code is shared
completely with this BSP variant.
This is minimalist configuration for the stm32h757i-eval BSP provided
here. The only general enhancement worth mention is boot core
configuration which is needed here as this is the first dual-core board
supported by stm32h7 BSP family and we need to choose boot core in order
to get C files compiling well.
The patch is needed due to smaller SRAM and completely disabled
SDRAM on the BSP variant.
Prefix the BSP family name with "bsps/" to make it distinct to the BSP
variant names.
Update #4468.
- Optionally add support for 'default-by-family' to allow
option to be set by a family and so all related BSPs
Close #4468
Update #3910.
