* | arm/lpc24xx: Use common test definition file | Sebastian Huber | 2021-09-21 | 1 | -72/+0 |
* | build: Merge default-by-family into by-variant | Sebastian Huber | 2021-08-18 | 1 | -1/+0 |
| | | | | | | | Prefix the BSP family name with "bsps/" to make it distinct to the BSP variant names. Update #4468. | ||||
* | build: Use BSP family for options | Chris Johns | 2021-07-15 | 1 | -0/+1 |
| | | | | | | | - Optionally add support for 'default-by-family' to allow option to be set by a family and so all related BSPs Close #4468 | ||||
* | build: Add test excludes | Sebastian Huber | 2021-01-26 | 1 | -0/+2 |
* | build: Add test excludes for RTEMS_PROFILING | Sebastian Huber | 2020-10-10 | 1 | -0/+1 |
* | build: Add test excludes for rcxx01 | Sebastian Huber | 2020-10-10 | 1 | -0/+1 |
* | build: Add test excludes for RTEMS_DEBUG | Sebastian Huber | 2020-10-06 | 1 | -0/+1 |
* | build: Add test excludes for RTEMS_DEBUG | Sebastian Huber | 2020-10-05 | 1 | -0/+1 |
| | | | | Close #4121. | ||||
* | build: Alternative build system based on waf | Sebastian Huber | 2020-09-14 | 1 | -0/+66 |
Update #3818. |
