* | bsps/arm: Use shared empty bsp_start_hook_0() | Sebastian Huber | 2024-01-15 | 1 | -0/+1 |
| | | | | Update #4982. | ||||
* | Update company name | Sebastian Huber | 2023-05-20 | 1 | -1/+1 |
| | | | | | The embedded brains GmbH & Co. KG is the legal successor of embedded brains GmbH. | ||||
* | spec/bsps: Do not install tm27.h | Chris Johns | 2022-08-22 | 1 | -1/+0 |
| | | | | Updates #4705 | ||||
* | bsps: Default to CPU counter benchmark timer | Sebastian Huber | 2022-01-15 | 1 | -1/+1 |
| | | | | | | Most BSPs which used the stubbed benachmark timer provide a CPU counter. All BSPs provide at least a stub CPU counter. Simply use the benchmark timer implementation using the CPU counter. | ||||
* | build: Use common objects item for get memory | Sebastian Huber | 2021-11-30 | 1 | -1/+0 |
* | bsps: Add default rtems_get_target_hash() | Sebastian Huber | 2021-02-26 | 1 | -0/+1 |
| | | | | Update #4267. | ||||
* | build: Alternative build system based on waf | Sebastian Huber | 2020-09-14 | 1 | -0/+55 |
Update #3818. |
