Update #4982.
This reverts commit 26d50bdfb601b9ef71ec2b30d2d9467c2437f443.
brains GmbH.
Merge the "default" and "default-by-variant" attributes. Use an
"enabled-by" expression to select the default value based on the enabled
set. This makes it possible to select default values depending on other
options. For example you could choose memory settings based on whether
RTEMS_SMP is enabled or disabled.
The change was tested by comparing the output of
./waf bspdefaults
before and after the change.
Replace the variant patterns in the default-by-variant list with an
explicit list of matching BSPs.
./waf bspdefaults
The beagle SPI functions are unusable by applications unless this file
is installed with the BSP. This ensures that the file is installed
properly.
Updates #4705
OPTIMIZATION_FLAGS must be defined before /build/bsp/bspopts is processed.
Update #4670.
Propagate the group defined cppflags, cflags, and cxxflags from parent groups
to child items through the build item context.
Update #4670.
Most BSPs which used the stubbed benachmark timer provide a CPU counter.
All BSPs provide at least a stub CPU counter. Simply use the benchmark
timer implementation using the CPU counter.
Prefix the BSP family name with "bsps/" to make it distinct to the BSP
variant names.
Update #4468.
- Optionally add support for 'default-by-family' to allow
option to be set by a family and so all related BSPs
Close #4468
Detects the SOC type using FDT and also replaces the ti_cpuid.h
header in FreeBSD with custom one.
Update #4267.
Update #3818.
