This adds the glue code necessary to allow JFFS2 to operate on top of
NAND memory hosted by the XNandPsu peripheral/driver.
This adds Xilinx's driver for the Xilinx NAND controller embedded in the
ZynqMP SoC. Within that device alone, it is possible to access this
peripheral from MicroBlaze, ARMv7, and ARMv8 cores. This has been added
to the hardware ZynqMP BSPs since QEMU does not support emulation of
this peripheral. This driver supports polled operation only. The
imported files are and should be able to remain unmodified. Import
information is kept in bsps/shared/dev/nand/VERSION.
Propagate the group defined cppflags, cflags, and cxxflags from parent groups
to child items through the build item context.
Update #4670.
Added I2C drivers for ZynqMP and updated build system accordingly.
Add the BSPs for running on the ZU3EG Ultrascale+ Zynq MPSoC and alter
the option defaults necessary for them to run properly using the
standard BOOT.BIN configured for PetaLinux that comes in the Out-of-Box
package.
