Merge the "default" and "default-by-variant" attributes. Use an
"enabled-by" expression to select the default value based on the enabled
set. This makes it possible to select default values depending on other
options. For example you could choose memory settings based on whether
RTEMS_SMP is enabled or disabled.
The change was tested by comparing the output of
./waf bspdefaults
before and after the change.
This adds SMP support for AArch64 in cpukit and for the ZynqMP BSPs.
Prefix the BSP family name with "bsps/" to make it distinct to the BSP
variant names.
Update #4468.
- Optionally add support for 'default-by-family' to allow
option to be set by a family and so all related BSPs
Close #4468
Add the BSPs for running on the ZU3EG Ultrascale+ Zynq MPSoC and alter
the option defaults necessary for them to run properly using the
standard BOOT.BIN configured for PetaLinux that comes in the Out-of-Box
package.
The current ZynqMP BSPs don't have _qemu in their name as do all other
RTEMS BSPs that are specifically made to run on QEMU. This fixes the
naming for those ZynqMP BSP variants for easier identification.
This adds a BSP family that runs on the Xilinx Ultrascale+ MPSOC
(ZynqMP) family of chips. It is configured to be usable on the Qemu
ZCU102 machine definition and should be almost trivially portable to
ZynqMP development boards and custom hardware. It is also configured to
be usable with libbsd.
