Ralf's patch to split the .spec files into multiple ".add" parts.
for RTEMS toolkit.
that contains:
regarded as bugs).
now works).
* removes libbsp/bare/wrapup
* Further cleanups
packages.
Cygwin support to the RPM scripts. The patch from David did not
apply cleanly and Joel ended up making all the modifications
plus some it should have included for consistency by hand. His comments:
I've included a diff against the last (19991203) snapshot RPM scripts that
adds what I think is required for Cygwin support. Basically all this boils
down to is adding EXE extension support. I've added the AC_EXEEXT rule to
conifgure.in (requires a valid 'cc' to work - this is not available in the
standard Cygwin distro). Each of the *.spec.in have @exe_ext@ includes in
them for each program that results in an EXE. The only odity here is that
the chill driver program is a shell script and thus does not require .exe to
be added... The mk*.in have all been updated to process the new exe_ext
rule.
splits gcc, gcj, chill, f77 and objc into separate rpms..
Ralf Corsepius <corsepiu@faw.uni-ulm.de>:
Most significant changes:
* Names for rpms changed again
* gccnewlib.rpm split into 3 rpms, one for chill, gcj, gcc (includes
c/c++/f77/objc), simultaneously built from a common *.spec.
* small patches with major impact to gcc and newlib (Those fixes
mentioned to Ian, ie. libobjc/libchill are built, multilibing works)
* gcc patch against gcc-2.95.2 (Should also apply to gcc-2.95.1 without
major problems)
* Buildroot removed from */*spec.in
* New: rpm Group: "rtems" (rpm -q -g rtems reports all RTEMS packages)
Changed package name so generated RPM would have a nicer name.
issue and has mkbspspec in a better state. user.cfg is now
gone.
There are some miscellaneous changes to buildall done by Joel
to clean up the build process.
functioned.
Merged Ralf's changes into gccnewlib.spec.in.
Ralf's end of day version.
