* | Remove (Obsolete). | Ralf Corsepius | 2007-01-08 | 72 | -5645/+0 |
* | Remove (Obsolete) | Ralf Corsepius | 2007-01-08 | 9 | -499/+0 |
* | 2006-12-02 Ralf Corsépius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2006-12-02 | 2 | -1/+5 |
| | | | | * configure.ac: New BUG-REPORT address. | ||||
* | 2006-07-04 Ralf Corsépius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2006-07-04 | 2 | -5/+7 |
| | | | | * autotools/autoconf.add: autoconf-2.60. | ||||
* | 2006-03-08 Joel Sherrill <joel@oarcorp.com> | Joel Sherrill | 2006-03-08 | 2 | -8/+12 |
| | | | | * setup.def: Update tool versions to gcc 4.0.2/newlib 1.14.0 | ||||
* | Be less restrictive on picking up target tools to enable using rpm.specs for ↵ | Ralf Corsepius | 2006-02-09 | 1 | -29/+3 |
| | | | | | | DOSish OSes. Generalize comments. | ||||
* | Conditionally remove manpage of DOS tools. | Ralf Corsepius | 2006-02-09 | 1 | -4/+11 |
* | 2006-02-09 Ralf Corsepius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2006-02-09 | 1 | -0/+4 |
| | | | | | | | * binutils/binutils.add: Conditionally remove manpage of DOS tools. * binutils/target-binutils.add: Be less restrictive on picking up target tools to enable using rpm.specs for DOSish OSes. Generalize comments. | ||||
* | 2006-02-09 Ralf Corsepius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2006-02-09 | 2 | -2/+7 |
| | | | | | * common/common.add.in: Add mingw exeext magic. Remove stray tab. | ||||
* | 2006-02-05 Ralf Corsepius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2006-02-05 | 2 | -1/+12 |
| | | | | * gccnewlib/mkspec.in: Split patches. | ||||
* | 2006-02-05 Ralf Corsepius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2006-02-05 | 2 | -24/+93 |
| | | | | | * gccnewlib/gccnewlib.add: Dynamically create brp-*. Use split source tar balls. | ||||
* | 2006-02-05 Ralf Corsepius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2006-02-05 | 2 | -20/+35 |
| | | | | | * binutils/binutils.add: Dynamically create brp-*. Misc. update. | ||||
* | Add BuildRoot. | Ralf Corsepius | 2005-12-29 | 4 | -1/+5 |
* | 2005-12-29 Ralf Corsepius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2005-12-29 | 1 | -0/+3 |
| | | | | | * gdb/gdb.add, rtems/rtems.add, rtemsdoc/rtemsdoc.add: Add BuildRoot. | ||||
* | 2005-12-29 Ralf Corsepius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2005-12-29 | 1 | -1/+3 |
| | | | | | * cpukit/rtems-cpukit: Add BuildRoot. * gccnewlib/gccnewlib.add: Add BuildRoot. | ||||
* | Add BuildRoot: | Ralf Corsepius | 2005-12-29 | 1 | -0/+1 |
* | 2005-12-29 Ralf Corsepius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2005-12-29 | 1 | -0/+2 |
| | | | | | * binutils/binutils.add: Remove BuildRoot. Don't build infos for prefix==/usr. | ||||
* | Remove BuildRoot. Don't build infos for prefix==/usr. | Ralf Corsepius | 2005-12-29 | 1 | -4/+12 |
* | 2005-12-29 Ralf Corsepius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2005-12-29 | 1 | -0/+1 |
| | | | | * common/common.add.in: Remove BuildRoot. | ||||
* | Remove BuildRoot. | Ralf Corsepius | 2005-12-29 | 1 | -3/+0 |
* | 2005-12-29 Ralf Corsepius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2005-12-29 | 1 | -0/+5 |
| | | | | | * autotools/autoconf.add, autotools/automake.add: Add BuildRoot. Remove Packager. | ||||
* | Add BuildRoot. Remove Packager. | Ralf Corsepius | 2005-12-29 | 2 | -5/+4 |
* | Cosmetics. | Ralf Corsepius | 2005-12-22 | 1 | -7/+18 |
* | Cosmetics to make rpmlint happy. | Ralf Corsepius | 2005-12-22 | 6 | -6/+6 |
* | Cosmetics. | Ralf Corsepius | 2005-12-21 | 10 | -18/+20 |
* | Drop Epoch:, Packager:. | Ralf Corsepius | 2005-12-21 | 1 | -2/+0 |
* | 2005-12-21 Ralf Corsepius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2005-12-21 | 2 | -11/+17 |
| | | | | * gdb/gdb.add: Add URL:. | ||||
* | 2005-12-19 Ralf Corsepius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2005-12-19 | 1 | -0/+7 |
| | | | | | | | * binutils/binutils.add: Add URL:. * gccnewlib/gccnewlib.add: Add URL:. Use Source50/Patch50 for newlib. * gccnewlib/mkspec.in: Use Source50/Patch50 for newlib. | ||||
* | Use Source50/Patch50 for newlib. | Ralf Corsepius | 2005-12-19 | 1 | -3/+3 |
* | Add URL:. | Ralf Corsepius | 2005-12-19 | 1 | -10/+12 |
* | Add URL:. | Ralf Corsepius | 2005-12-19 | 1 | -0/+1 |
* | Cosmetics | Ralf Corsepius | 2005-12-19 | 9 | -2/+10 |
* | Cosmetics. | Ralf Corsepius | 2005-12-19 | 3 | -10/+13 |
* | Add __os_install_post. | Ralf Corsepius | 2005-12-18 | 4 | -0/+12 |
* | Remove __os_install_post. | Ralf Corsepius | 2005-12-18 | 1 | -3/+0 |
* | 2005-12-18 Ralf Corsepius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2005-12-18 | 1 | -0/+6 |
| | | | | | | * common/common.add.in: Remove __os_install_post. * cpukit/rtems-cpukit.add, gdb/gdb.add, rtems/rtems.add, rtemsdoc/rtemsdoc.add: Add __os_install_post. | ||||
* | Remove Packager: | Ralf Corsepius | 2005-12-18 | 1 | -1/+0 |
* | 2005-11-21 Ralf Corsepius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2005-11-21 | 2 | -6/+14 |
| | | | | | * gccnewlib/gccnewlib.add: Rename src.rpm back to gcc-newlib.src.rpm. Misc fixups. | ||||
* | 2005-11-21 Ralf Corsepius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2005-11-21 | 1 | -0/+4 |
| | | | | | | | * gccnewlib/target-c++.add, gccnewlib/target-g77.add, gccnewlib/target-gcc.add, gccnewlib/target-gcj.add, gccnewlib/target-gfortran.add, gccnewlib/target-gnat.add gccnewlib/target-objc.add: Add License. | ||||
* | Add License. | Ralf Corsepius | 2005-11-21 | 7 | -2/+13 |
* | Re-sort sub-package fragments. | Ralf Corsepius | 2005-11-21 | 1 | -6/+6 |
* | Add License. | Ralf Corsepius | 2005-11-21 | 5 | -1/+6 |
* | 2005-11-21 Ralf Corsepius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2005-11-21 | 1 | -0/+6 |
| | | | | | | * gccnewlib/base-g77.add, gccnewlib/base-gcc.add, gccnewlib/base-gcj.add, gccnewlib/base-gfortran.add, gccnewlib/base-gnat.add: Add License. | ||||
* | 2005-10-31 Ralf Corsepius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2005-10-31 | 3 | -7/+14 |
| | | | | | | * gccnewlib/gccnewlib.add: Rename src.rpm to *-gcc.src.rpm. * gccnewlib/target-gcc.add: Reflect changes above. * gccnewlib/Makefile.am: Re-sort sub-package fragments. | ||||
* | 2005-09-15 Ralf Corsepius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2005-09-15 | 2 | -0/+7 |
| | | | | | * gccnewlib/gccnewlib.add: Pass CC="%__cc $RPM_OPT_FLAGS" to configure. | ||||
* | 2005-09-15 Ralf Corsepius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2005-09-15 | 1 | -0/+5 |
| | | | | | * gccnewlib/gccnewlib.add, gdb/gdb.add: Append %_bindir to PATH only if %_prefix != /usr. | ||||
* | Append %_bindir to PATH only if %_prefix != /usr. | Ralf Corsepius | 2005-09-15 | 2 | -0/+4 |
* | 2005-09-15 Ralf Corsepius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2005-09-15 | 1 | -0/+7 |
| | | | | | | | * configure.ac: Remove GCC3NEWLIBVERS, BINUTILSVERS, GDBVERS. * binutils/Makefile.am: Generate unversioned *binutils.spec. * gccnewlib/Makefile.am: Generate unversioned *gcc-newlib.spec. * gdb/Makefile.am: Generate unversioned *gdb.spec. | ||||
* | Generate unversioned *gdb.spec. | Ralf Corsepius | 2005-09-15 | 1 | -26/+26 |
* | Generate unversioned *gcc-newlib.spec. | Ralf Corsepius | 2005-09-15 | 1 | -24/+24 |
