* Makefile.am: Remove reference to mkbinutilsspec.
* configure.ac: Remove EXEEXT check.
Add common/clean.add, common/common.add.
* binutils/mkspec.in: New.
* binutils/.cvsignore: Add mkspec.
* mkbinutilspec.in: Remove.
* gdb/Makefile.am: Depend on mkspec.
* binutils/binutils.add: Add @exe_ext@ to c++filt.
Add %_defaultbuildroot.
* ChangeLog: Fix yesterday's entry.
* gdb/target-gdb.add: %defattr(-,root,root).
Use %{_prefix} instead of /opt/rtems.
Misc. minor changes.
* gdb/gdb.add: Use %{_prefix} instead of /opt/rtems.
Remove stray unpackaged files.
Use %{_defaultbuildroot} instead of hard-coded values.
configure --disable-nls.
Add BuildPreReq: ncurses-devel.
* gdb/base-gdb.add: %defattr(-,root,root).
* gdb/mkspec.in: New.
* gdb/Makefile.am: Reflect addition of gdb/mkspec.in.
* gcc3newlib/mkspec.in: Fix usage.
* gcc3newlib/gccnewlib.add: Use %{_defaultbuildroot} instead of
hard-coded values. Update copyright notice.
* mkgdbspec.in: Removed.
* Makefile.am: Remove mkgdbspec.
* configure.ac: Remove mkgdbspec.
Add gdb/mkspec.
* configure.ac: Add rtemsdoc.
* Makefile.ac: Add rtemsdoc.
* rtemsdoc/README: New.
* rtemsdoc/.cvsignore: New.
* autotools/autoconf-rtems.spec.in: New.
Remove Provides: autoconf (Conflicts with RH-8.0).
* autotools/autoconf-rtems.spec: Remove.
* autotools/automake-rtems.spec.in:
Remove Provides: automake (Conflicts with RH-8.0).
* gcc3newlib/Makefile.am: Remove references to mkgcc3newlibspec.
* Makefile.am: Ditto.
* configure.ac: Add autotools/autoconf-rtems.spec.in.
* mkgcc3newlibspec.in: Remove
* gcc3newlib/mkspec.in: New.
* gcc3newlib/gccnewlib.add: Add build_XXX defines.
Add preliminary gnat support.
* gcc3newlib/base-g77.add: Add build_g77.
* gcc3newlib/base-gcj.add: Add build_gcj.
* gcc3newlib/base-gnat.add: New.
* gcc3newlib/target-c++.add: Add build_cxx.
* gcc3newlib/target-g77.add: Add build_g77.
* gcc3newlib/target-gcj.add: Add build_gcj.
* gcc3newlib/target-objc.add: Add build_objc.
* gcc3newlib/target-gnat.add: New.
* gcc3newlib/Makefile.am: Use ./mkspec. Use unified spec.
* configure.ac: Use AC_CONFIG_FILES(script, chmod +x script)
to generate mk*spec scripts.
* mkbspspec.in: Use ',' as pattern delimiter in sed expression
for $rpm_build_root.
* mkbinutilsspec.in: Use ',' as pattern delimiter in sed
expression for $rpm_build_root.
* cpukit/mkspec.in: Cosmetical changes.
* ChangeLog: Fix 2002-07-22 ChangeLog entry bogusly referring to
Joel.
* cpukit/Makefile.am: New.
* cpukit/mkspec.in: New.
* cpukit/rtems-cpukit.spec.in: New.
* cpukit/.cvsignore: New.
* configure.ac: Add cpukit.
Add RTEMS_TOP to pickup _RTEMS_VERSION (required by cpukit).
* Makefile.am: Add cpukit. Add ACLOCAL_AMFLAGS (required to pickup
RTEMS_VERSION).
* setup.def: Use %{_tmppath} as default for $rpm_build_root.
* mkbinutilsspec.in: Use ',' as pattern delimiter in sed expression
* mkgccnewlibspec.in: Use ',' as pattern delimiter in sed
* mkgcc3newlibspec.in: Use ',' as pattern delimiter in sed
* mkgdbspec.in: Use ',' as pattern delimiter in sed expression for
$rpm_build_root.
* Per PR64 added support for gcc 3.x RPMs
* Makefile.am, configure.ac, mkspec, setup, setup.def: Modified.
* mkgcc3newlibspec.in: New file.
* gcc3newlib: New subdirectory.
* base-g77.add, base-gcc.add, base-gcj.add, gccnewlib.add,
gccnewlib_c_only.spec.in, gccnewlib.spec.in, HISTORY, Makefile.am,
README, target-g77.add, target-gcc.add, target-gcj.add,
target-objc.add: New files.
* autotools/Makefile.am: Remove AUTOMAKE_OPTIONS.
* binutils/Makefile.am: Remove AUTOMAKE_OPTIONS.
* gccnewlib/Makefile.am: Remove AUTOMAKE_OPTIONS.
* gdb/Makefile.am: Remove AUTOMAKE_OPTIONS.
* PR151
* autotools/automake-rtems.spec.in: New.
* autotools/automake-rtems.spec: Removed.
* configure.ac: Be a little more lenient in matching sparc-solaris.
* configure.ac: Add AC_PREFIX_DEFAULT([/opt/rtems]).
* mkbinutilsspec.in: Add propagation of @prefix@.
* binutils/base-binutils.add:
Let %post and %unpost apply %{_prefix}.
Apply %{_prefix} instead of /opt/rtems.
* binutils/binutils.add: Update copyright notice.
Add _prefix.
Remove -a 0 in %setup.
Rework hack to SuSE's rpm screwing up %{_target}.
Replace ARGS with CONFIGURE_ARGS.
* binutils/target-binutils.add:
* configure.ac: Fix typo to allow custom RPM_SPECSdirs.
* mkbinutilsspec.in: Guard sed-pattern against autoconf.
* mkgccnewlibspec.in: Guard sed-pattern against autoconf, remove
Target_alias.
* mkgdbspec.in: Guard sed-pattern against autoconf.
* mkbspspec.in: Guard sed-pattern against autoconf.
* configure.ac: Rework check for RPM_SPECSdir.
* autotools/automake-rtems.spec: Update to automake-1.5.
* configure.in: Remove.
