path: root/scripts/README (follow)
* Remove (Obsolete).Ralf Corsepius2007-01-081-255/+0
* 2001-01-24 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2002-01-241-0/+17
| | | | * README: Added Canadian Cross instructions.
* Working on being able to cut RPMs. It now appears that the processJoel Sherrill1999-10-181-10/+154
| | | | | | | | | | | | | is working mostly for sparc at least. There is one major problem -- the current process generates a unique source file per RPM when in fact all of the source files are nearly the same -- it is only the spec part of the rpm which differs. The new file mkbinutils_subpackage_version is an attempt to address this. It does part of the job right -- one source file produces multiple binary RPMs. BUT the end user can not produce the resulting RPMS themselves from SRPMS unless they also build all targets.
* Ralf Corsepius (corsepiu@faw.uni-ulm.de) submitted these scripts toJoel Sherrill1999-10-151-0/+94
help build RPMs.
