path: root/doc/supplements (follow)
* Changed copyright date to 1999.Joel Sherrill1999-11-16101-101/+101
* Fixing many lines that are too long to format cleanly.Joel Sherrill1999-10-252-3/+5
* Cleaned up to install dvi, use native texi2dvi, etc..Joel Sherrill1999-10-119-45/+54
* Remove $(PROJECT).pdf not *.pdf. We were accidentally removing theJoel Sherrill1999-10-079-9/+9
| | | | pdf version of figures.
* Enabled table of contents generation so the left hand side of the PDFJoel Sherrill1999-10-079-9/+9
| | | | viewer can have section headings.
* Numerous minor changes required to transition to the latest versionJoel Sherrill1999-10-0118-27/+72
| | | | | of texinfo and TeX. This version of the tools can produce PDF with figures included.
* Removed concept of distribution level.Joel Sherrill1999-07-039-9/+0
* Changed date.Joel Sherrill1999-04-231-0/+2
* Added info based on i960HA support.Joel Sherrill1999-04-191-10/+8
* First Cut at Hitachi SH.Joel Sherrill1998-11-2512-0/+1222
* New files copied from template and personalized.Joel Sherrill1998-11-2312-0/+1314
* Applied updates from remote work while doing class.Joel Sherrill1998-11-197-98/+84
* Moved things around so html and clean were above stanzas which generateJoel Sherrill1998-10-197-113/+107
| | | | chapters.
* All of the Supplemental manuals are now generated as automaticallyJoel Sherrill1998-10-1922-511/+159
| | | | as possible.
* No node infoJoel Sherrill1998-10-191-45/+1
* Renamed.Joel Sherrill1998-10-193-645/+0
* Renamed memmodel.texi to memmodel.t.Joel Sherrill1998-10-191-119/+0
* Renamed fatalerr.texi to fatalerr.t.Joel Sherrill1998-10-191-47/+0
* Renamed cputable.texi to cputable.t.Joel Sherrill1998-10-191-119/+0
* Renamed cpumodel.texi to cpumodel.t.Joel Sherrill1998-10-191-171/+0
* Renamed callconv.texi to callconv.t.Joel Sherrill1998-10-191-447/+0
* Renamed bsp.texi to bsp.t.Joel Sherrill1998-10-191-106/+0
* Renamed a lot and got as much as possible automatically generated.Joel Sherrill1998-10-1911-349/+91
* Renamed.Joel Sherrill1998-10-191-215/+0
* RenamedJoel Sherrill1998-10-193-1671/+0
* Renamed memmodel.texi to memmodel.t.Joel Sherrill1998-10-191-125/+0
* Renamed fatalerr.texi to fatalerr.t.Joel Sherrill1998-10-191-62/+0
* Renamed cputable.texi to cputable.t.Joel Sherrill1998-10-191-171/+0
* Renamed cpumodel.texi to cpumodel.t.Joel Sherrill1998-10-191-223/+0
* Renamed callconv.texi to callconv.t.Joel Sherrill1998-10-191-280/+0
* Renamed bsp.texi to bsp.t.Joel Sherrill1998-10-191-95/+0
* Much renamed, most stuff automatically generated now.Joel Sherrill1998-10-1911-357/+31
* Renamed a lot of files.Joel Sherrill1998-10-198-764/+41
* Nearly everything that can be is now automatically generated.Joel Sherrill1998-10-1918-1183/+92
* All files as automatically generated as possible.Joel Sherrill1998-10-197-218/+18
* Renamed.Joel Sherrill1998-10-191-0/+0
* New file.Joel Sherrill1998-10-191-0/+86
* Removed.Joel Sherrill1998-10-192-241/+0
* More automatically generated. Many files renamed behind the scenes.Joel Sherrill1998-10-1910-872/+45
* Makefiles in much better shape even though not all files have automaticallyJoel Sherrill1998-10-1922-102/+223
| | | | generated menus yet.
* Timing Chapter is now shared and menu structure generated.Joel Sherrill1998-10-194-32/+47
| | | | Cpumodel.texi is now generated.
* Now completed generated with build menu.Joel Sherrill1998-10-192-37/+51
* New fileJoel Sherrill1998-10-191-0/+108
* Worksheets now generated from a common file and the node info structureJoel Sherrill1998-10-198-85/+194
| | | | is generated automatically.
* Added chapter.Joel Sherrill1998-10-193-6/+123
* Added chapter.Joel Sherrill1998-10-192-2/+95
* Added chapter.Joel Sherrill1998-10-193-3/+40
* Added chapter.Joel Sherrill1998-10-194-5/+246
* Added chapter.Joel Sherrill1998-10-192-6/+263
* Added.Joel Sherrill1998-10-193-3/+100
