* | Removed -- temporary files. | Joel Sherrill | 2000-04-27 | 8 | -11515/+0 |
* | Patch rtemsdoc-4.5.0-rc-0.diff from Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Joel Sherrill | 2000-04-26 | 39 | -1507/+12606 |
| | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | which contains the bulk of converting the documentation tree to automake and GNU conventions. Comments follow: This is the automake port of rtemsdoc. To apply: cvs co rtemsdoc cd rtemsdoc sh cvs-rm.sh patch -p0 < rtemsdoc-4.5.0-rc-0.diff sh cvs-add.sh [Attention: cvs-rm.sh and cvs-add.sh directly modify cvs] Known bugs: 1) src2html is not supported (yet? - Is this supposed to work?) 2) all *.pdf images now are generated on-the-fly, but not yet deleted during "make distclean" 3) All supplements, including the templated ones, get build and installed. 4) Building outside of the source tree is completely untested and very likely does not work. 5) Make [ps|pdf] are not (yet) supported, make [dvi|info] are supported by automake's default texinfo rules. Fixing 2, 3 and 5 is almost trivial and needs to be done. 4) is a matter of testing and tool-properties, for now it is simply untested. General issues: * gif vs jpg vs png. I would recommend to replace all images with pngs to avoid potential copyright issues (gif) or lack in quality (jpg, jpg is good for real world photographs, but extremely poor on artificial images, graphs). * pdf images do net get placed correctly in pdf-documents. * texinfo: We now use a local copy of texinfo-4.0's texinfo.tex in texinfo/texinfo.tex for generating infos. However pdftex's system-wide texinfo.tex and pdftexinfo.tex are used for generating *.dvi, *.ps, *.pdf. * .cvsignore files still missing. * I have renamed the supplements filename not to use c_<supplement>, because automake seems to have problems with it. Notes: * Again, I recommend not to put any generated files into CVS. Here, this comprises some *texi, all *.pdf and many *.html pages. Ie. I recommend to run make maintainer-clean before checking in any files. * To get building started, this should be sufficient: ./bootstrap ./configure cd tools; make; cd .. make info * To make a public tarball: [cvs co ; ./bootstrap] ./configure cd tools; make; cd .. make info [make clean] make dist => This generates a rtems-<version>.tar.gz in the toplevel directory. => Building the tools only is required after a "cvs co", but not in a distribution tarball. | ||||
* | Changed copyright date to 1999. | Joel Sherrill | 1999-11-16 | 101 | -101/+101 |
* | Fixing many lines that are too long to format cleanly. | Joel Sherrill | 1999-10-25 | 2 | -3/+5 |
* | Cleaned up to install dvi, use native texi2dvi, etc.. | Joel Sherrill | 1999-10-11 | 9 | -45/+54 |
* | Remove $(PROJECT).pdf not *.pdf. We were accidentally removing the | Joel Sherrill | 1999-10-07 | 9 | -9/+9 |
| | | | | pdf version of figures. | ||||
* | Enabled table of contents generation so the left hand side of the PDF | Joel Sherrill | 1999-10-07 | 9 | -9/+9 |
| | | | | viewer can have section headings. | ||||
* | Numerous minor changes required to transition to the latest version | Joel Sherrill | 1999-10-01 | 18 | -27/+72 |
| | | | | | of texinfo and TeX. This version of the tools can produce PDF with figures included. | ||||
* | Removed concept of distribution level. | Joel Sherrill | 1999-07-03 | 9 | -9/+0 |
* | Changed date. | Joel Sherrill | 1999-04-23 | 1 | -0/+2 |
* | Added info based on i960HA support. | Joel Sherrill | 1999-04-19 | 1 | -10/+8 |
* | First Cut at Hitachi SH. | Joel Sherrill | 1998-11-25 | 12 | -0/+1222 |
* | New files copied from template and personalized. | Joel Sherrill | 1998-11-23 | 12 | -0/+1314 |
* | Applied updates from remote work while doing class. | Joel Sherrill | 1998-11-19 | 7 | -98/+84 |
* | Moved things around so html and clean were above stanzas which generate | Joel Sherrill | 1998-10-19 | 7 | -113/+107 |
| | | | | chapters. | ||||
* | All of the Supplemental manuals are now generated as automatically | Joel Sherrill | 1998-10-19 | 22 | -511/+159 |
| | | | | as possible. | ||||
* | No node info | Joel Sherrill | 1998-10-19 | 1 | -45/+1 |
* | Renamed. | Joel Sherrill | 1998-10-19 | 3 | -645/+0 |
* | Renamed memmodel.texi to memmodel.t. | Joel Sherrill | 1998-10-19 | 1 | -119/+0 |
* | Renamed fatalerr.texi to fatalerr.t. | Joel Sherrill | 1998-10-19 | 1 | -47/+0 |
* | Renamed cputable.texi to cputable.t. | Joel Sherrill | 1998-10-19 | 1 | -119/+0 |
* | Renamed cpumodel.texi to cpumodel.t. | Joel Sherrill | 1998-10-19 | 1 | -171/+0 |
* | Renamed callconv.texi to callconv.t. | Joel Sherrill | 1998-10-19 | 1 | -447/+0 |
* | Renamed bsp.texi to bsp.t. | Joel Sherrill | 1998-10-19 | 1 | -106/+0 |
* | Renamed a lot and got as much as possible automatically generated. | Joel Sherrill | 1998-10-19 | 11 | -349/+91 |
* | Renamed. | Joel Sherrill | 1998-10-19 | 1 | -215/+0 |
* | Renamed | Joel Sherrill | 1998-10-19 | 3 | -1671/+0 |
* | Renamed memmodel.texi to memmodel.t. | Joel Sherrill | 1998-10-19 | 1 | -125/+0 |
* | Renamed fatalerr.texi to fatalerr.t. | Joel Sherrill | 1998-10-19 | 1 | -62/+0 |
* | Renamed cputable.texi to cputable.t. | Joel Sherrill | 1998-10-19 | 1 | -171/+0 |
* | Renamed cpumodel.texi to cpumodel.t. | Joel Sherrill | 1998-10-19 | 1 | -223/+0 |
* | Renamed callconv.texi to callconv.t. | Joel Sherrill | 1998-10-19 | 1 | -280/+0 |
* | Renamed bsp.texi to bsp.t. | Joel Sherrill | 1998-10-19 | 1 | -95/+0 |
* | Much renamed, most stuff automatically generated now. | Joel Sherrill | 1998-10-19 | 11 | -357/+31 |
* | Renamed a lot of files. | Joel Sherrill | 1998-10-19 | 8 | -764/+41 |
* | Nearly everything that can be is now automatically generated. | Joel Sherrill | 1998-10-19 | 18 | -1183/+92 |
* | All files as automatically generated as possible. | Joel Sherrill | 1998-10-19 | 7 | -218/+18 |
* | Renamed. | Joel Sherrill | 1998-10-19 | 1 | -0/+0 |
* | New file. | Joel Sherrill | 1998-10-19 | 1 | -0/+86 |
* | Removed. | Joel Sherrill | 1998-10-19 | 2 | -241/+0 |
* | More automatically generated. Many files renamed behind the scenes. | Joel Sherrill | 1998-10-19 | 10 | -872/+45 |
* | Makefiles in much better shape even though not all files have automatically | Joel Sherrill | 1998-10-19 | 22 | -102/+223 |
| | | | | generated menus yet. | ||||
* | Timing Chapter is now shared and menu structure generated. | Joel Sherrill | 1998-10-19 | 4 | -32/+47 |
| | | | | Cpumodel.texi is now generated. | ||||
* | Now completed generated with build menu. | Joel Sherrill | 1998-10-19 | 2 | -37/+51 |
* | New file | Joel Sherrill | 1998-10-19 | 1 | -0/+108 |
* | Worksheets now generated from a common file and the node info structure | Joel Sherrill | 1998-10-19 | 8 | -85/+194 |
| | | | | is generated automatically. | ||||
* | Added chapter. | Joel Sherrill | 1998-10-19 | 3 | -6/+123 |
* | Added chapter. | Joel Sherrill | 1998-10-19 | 2 | -2/+95 |
* | Added chapter. | Joel Sherrill | 1998-10-19 | 3 | -3/+40 |
* | Added chapter. | Joel Sherrill | 1998-10-19 | 4 | -5/+246 |
