* | 2006-08-23 Joel Sherrill <joel@OARcorp.com> | Joel Sherrill | 2006-08-23 | 1 | -112/+0 |
| | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | * Makefile.am, configure.ac, FAQ/stamp-vti, FAQ/version.texi, common/cpright.texi: Merging CPU Supplements into a single document. As part of this removed the obsolete and impossible to maintain size and timing information. * cpu_supplement/.cvsignore, cpu_supplement/Makefile.am, cpu_supplement/arm.t, cpu_supplement/i386.t, cpu_supplement/m68k.t, cpu_supplement/mips.t, cpu_supplement/powerpc.t, cpu_supplement/preface.texi, cpu_supplement/sh.t, cpu_supplement/sparc.t, cpu_supplement/tic4x.t: New files. * supplements/.cvsignore, supplements/Makefile.am, supplements/supplement.am, supplements/arm/.cvsignore, supplements/arm/BSP_TIMES, supplements/arm/ChangeLog, supplements/arm/Makefile.am, supplements/arm/arm.texi, supplements/arm/bsp.t, supplements/arm/callconv.t, supplements/arm/cpumodel.t, supplements/arm/cputable.t, supplements/arm/fatalerr.t, supplements/arm/intr_NOTIMES.t, supplements/arm/memmodel.t, supplements/arm/preface.texi, supplements/arm/timeBSP.t, supplements/c4x/.cvsignore, supplements/c4x/BSP_TIMES, supplements/c4x/ChangeLog, supplements/c4x/Makefile.am, supplements/c4x/bsp.t, supplements/c4x/c4x.texi, supplements/c4x/callconv.t, supplements/c4x/cpumodel.t, supplements/c4x/cputable.t, supplements/c4x/fatalerr.t, supplements/c4x/intr_NOTIMES.t, supplements/c4x/memmodel.t, supplements/c4x/preface.texi, supplements/c4x/timeBSP.t, supplements/i386/.cvsignore, supplements/i386/ChangeLog, supplements/i386/FORCE386_TIMES, supplements/i386/Makefile.am, supplements/i386/bsp.t, supplements/i386/callconv.t, supplements/i386/cpumodel.t, supplements/i386/cputable.t, supplements/i386/fatalerr.t, supplements/i386/i386.texi, supplements/i386/intr_NOTIMES.t, supplements/i386/memmodel.t, supplements/i386/preface.texi, supplements/i386/timeFORCE386.t, supplements/m68k/.cvsignore, supplements/m68k/ChangeLog, supplements/m68k/MVME136_TIMES, supplements/m68k/Makefile.am, supplements/m68k/bsp.t, supplements/m68k/callconv.t, supplements/m68k/cpumodel.t, supplements/m68k/cputable.t, supplements/m68k/fatalerr.t, supplements/m68k/intr_NOTIMES.t, supplements/m68k/m68k.texi, supplements/m68k/memmodel.t, supplements/m68k/preface.texi, supplements/m68k/timeMVME136.t, supplements/m68k/timedata.t, supplements/mips/.cvsignore, supplements/mips/BSP_TIMES, supplements/mips/ChangeLog, supplements/mips/Makefile.am, supplements/mips/bsp.t, supplements/mips/callconv.t, supplements/mips/cpumodel.t, supplements/mips/cputable.t, supplements/mips/fatalerr.t, supplements/mips/intr_NOTIMES.t, supplements/mips/memmodel.t, supplements/mips/mips.texi, supplements/mips/preface.texi, supplements/mips/timeBSP.t, supplements/powerpc/.cvsignore, supplements/powerpc/ChangeLog, supplements/powerpc/DMV177_TIMES, supplements/powerpc/Makefile.am, supplements/powerpc/PSIM_TIMES, supplements/powerpc/bsp.t, supplements/powerpc/callconv.t, supplements/powerpc/cpumodel.t, supplements/powerpc/cputable.t, supplements/powerpc/fatalerr.t, supplements/powerpc/intr_NOTIMES.t, supplements/powerpc/memmodel.t, supplements/powerpc/powerpc.texi, supplements/powerpc/preface.texi, supplements/powerpc/timeDMV177.t, supplements/powerpc/timePSIM.t, supplements/sh/.cvsignore, supplements/sh/BSP_TIMES, supplements/sh/ChangeLog, supplements/sh/Makefile.am, supplements/sh/bsp.t, supplements/sh/callconv.t, supplements/sh/cpumodel.t, supplements/sh/cputable.t, supplements/sh/fatalerr.t, supplements/sh/intr_NOTIMES.t, supplements/sh/memmodel.t, supplements/sh/preface.texi, supplements/sh/sh.texi, supplements/sh/timeBSP.t, supplements/sparc/.cvsignore, supplements/sparc/ChangeLog, supplements/sparc/ERC32_TIMES, supplements/sparc/Makefile.am, supplements/sparc/bsp.t, supplements/sparc/callconv.t, supplements/sparc/cpumodel.t, supplements/sparc/cputable.t, supplements/sparc/fatalerr.t, supplements/sparc/intr_NOTIMES.t, supplements/sparc/memmodel.t, supplements/sparc/preface.texi, supplements/sparc/sparc.texi, supplements/sparc/timeERC32.t, supplements/template/.cvsignore, supplements/template/BSP_TIMES, supplements/template/ChangeLog, supplements/template/Makefile.am, supplements/template/bsp.t, supplements/template/callconv.t, supplements/template/cpumodel.t, supplements/template/cputable.t, supplements/template/fatalerr.t, supplements/template/intr_NOTIMES.t, supplements/template/memmodel.t, supplements/template/preface.texi, supplements/template/template.texi, supplements/template/timeBSP.t: Removed. | ||||
* | 2002-07-30 Joel Sherrill <joel@OARcorp.com> | Joel Sherrill | 2002-07-31 | 1 | -7/+11 |
| | | | | * intr_NOTIMES.t, timeBSP.t: Replaced XXX's with real info. | ||||
* | 2001-01-17 Joel Sherrill <joel@OARcorp.com> | Joel Sherrill | 2002-01-17 | 1 | -1/+1 |
| | | | | | | | * SUPPORT, LICENSE: New files. * Numerous files touched as part of merging the 4.5 branch onto the mainline development trunk and ensuring that the script that cuts snapshots and releases works on the documentation. | ||||
* | Patch rtems-rc-4.5.0-21.diff from Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Joel Sherrill | 2000-06-10 | 1 | -1/+1 |
| | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | which splits the current monolithic specs files into a sequence of subparts. These can be concatenated togather to make a the whole .spec file. This cleans up the maintenance problem of having "all languages" and a "C/C++ only" gccnewlib spec files. Plus it should make it easier to produce variants like the gdb-m68k-bdm which require special hackery. :) Ralf's comments: It addresses the way *.spec.in get composed inside of the source tree. Changes: * Each spec.in is broken into several files (*.add), one *.add file per sub-package. * Each Makefile.am composes spec.ins from the *.add files * Removal of redundant automake support files. * Default value for BuildRoot changed to /tmp/<spec-file-name> * %clean stage added to *specs Advantages (IMHO). * The *.add files are easier to adminstrate and more flexible in comparison to the former *.specs.ins. * gccnewlib_c_only.spec.in now is composed from the same sources as gccnewlib.spec.in (less errors) * If using the default BuildRoot --clean now deletes all files that were generated while building. Notes: * rtems.spec.in has not yet been adapted to the scheme used for the other *spec.ins * Except for cosmetical changes the internals of the *.spec files should not have changed. To Apply: cvs rm -f scripts/binutils/binutils.spec.in cvs rm -f scripts/gccnewlib/gccnewlib.spec.in cvs rm -f scripts/gccnewlib/gccnewlib_c_only.spec.in cvs rm -f scripts/gdb/gdb.spec.in cvs rm -f scripts/config.sub cvs rm -f scripts/config.guess cvs rm -f scripts/install-sh cvs rm -f scripts/mkinstalldirs cvs rm -f scripts/missing patch -p1 < rtems-rc-4.5.0-21.diff cvs add scripts/*/*.add cvs add scripts/*/README | ||||
* | Patch rtemsdoc-4.5.0-rc-0.diff from Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Joel Sherrill | 2000-04-26 | 1 | -5/+5 |
| | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | which contains the bulk of converting the documentation tree to automake and GNU conventions. Comments follow: This is the automake port of rtemsdoc. To apply: cvs co rtemsdoc cd rtemsdoc sh cvs-rm.sh patch -p0 < rtemsdoc-4.5.0-rc-0.diff sh cvs-add.sh [Attention: cvs-rm.sh and cvs-add.sh directly modify cvs] Known bugs: 1) src2html is not supported (yet? - Is this supposed to work?) 2) all *.pdf images now are generated on-the-fly, but not yet deleted during "make distclean" 3) All supplements, including the templated ones, get build and installed. 4) Building outside of the source tree is completely untested and very likely does not work. 5) Make [ps|pdf] are not (yet) supported, make [dvi|info] are supported by automake's default texinfo rules. Fixing 2, 3 and 5 is almost trivial and needs to be done. 4) is a matter of testing and tool-properties, for now it is simply untested. General issues: * gif vs jpg vs png. I would recommend to replace all images with pngs to avoid potential copyright issues (gif) or lack in quality (jpg, jpg is good for real world photographs, but extremely poor on artificial images, graphs). * pdf images do net get placed correctly in pdf-documents. * texinfo: We now use a local copy of texinfo-4.0's texinfo.tex in texinfo/texinfo.tex for generating infos. However pdftex's system-wide texinfo.tex and pdftexinfo.tex are used for generating *.dvi, *.ps, *.pdf. * .cvsignore files still missing. * I have renamed the supplements filename not to use c_<supplement>, because automake seems to have problems with it. Notes: * Again, I recommend not to put any generated files into CVS. Here, this comprises some *texi, all *.pdf and many *.html pages. Ie. I recommend to run make maintainer-clean before checking in any files. * To get building started, this should be sufficient: ./bootstrap ./configure cd tools; make; cd .. make info * To make a public tarball: [cvs co ; ./bootstrap] ./configure cd tools; make; cd .. make info [make clean] make dist => This generates a rtems-<version>.tar.gz in the toplevel directory. => Building the tools only is required after a "cvs co", but not in a distribution tarball. | ||||
* | Changed copyright date to 1999. | Joel Sherrill | 1999-11-16 | 1 | -1/+1 |
* | New file | Joel Sherrill | 1998-10-19 | 1 | -0/+108 |
