line option.
may suppress warnings.
erc32, imx, qoriq, etc.
* cpukit/include
* cpukit/libnetworking
* bsps/include
* bsps/@RTEMS_CPU@/include
order.
Update #3254.
Delete SCORE_INIT. This finally removes the
some.h:
#ifndef SOME_XYZ_EXTERN
#define SOME_XYZ_EXTERN extern
#endif
SOME_XYZ_EXTERN type xyz;
some_xyz.c:
#include <some.h>
pattern in favour of
some.h:
extern type xyz;
some_xyz.c
#include <some.h>
type xyz;
Update #2559.
Update #2408.
Merge systems states SYSTEM_STATE_SHUTDOWN and SYSTEM_STATE_FAILED into
new system state SYSTEM_STATE_TERMINATED. This reflects that all system
termination paths end up in _Internal_error_Occurred().
Nothing happened between the SYSTEM_STATE_BEGIN_MULTITASKING to
SYSTEM_STATE_UP transition.
This is the result of a sed script which converts all uses
of @{ into a consistent form.
Define _System_state_Current and _Internal_errors_What_happened in
interr.c to make _Internal_error_Occurred() more independent.
* score/include/rtems/score/sysstate.h: Spelling.
* score/include/rtems/debug.h, score/include/rtems/score/sysstate.h,
score/include/rtems/score/timespec.h,
score/inline/rtems/score/address.inl,
score/inline/rtems/score/stack.inl,
score/inline/rtems/score/states.inl: Add missing includes.
* rtems/src/taskmode.c, sapi/src/exshutdown.c,
score/inline/rtems/score/sysstate.inl: Added
_System_state_Is_shutdown(). Removed direct uses of
_System_state_Current. Documentation.
* score/include/rtems/score/sysstate.h,
score/inline/rtems/score/sysstate.inl, score/src/thread.c: Make
_System_state_Is_multiprocessing unused when multiprocessing is not
enabled. Saves one more variable from single processor configuration.
Large patch to improve Doxygen output. As a side-effect, grammar and
spelling errors were corrected, spacing errors were address, and some
variable names were improved.
* libmisc/monitor/mon-object.c, libmisc/monitor/monitor.h:
Account for changing OBJECTS_NO_CLASS to OBJECTS_CLASSIC_NO_CLASS.
* score/Doxyfile: Set output directory. Predefine some macro values.
Turn on graphical output.
* score/include/rtems/debug.h, score/include/rtems/seterr.h,
score/include/rtems/system.h, score/include/rtems/score/address.h,
score/include/rtems/score/apiext.h,
score/include/rtems/score/apimutex.h,
score/include/rtems/score/bitfield.h,
score/include/rtems/score/chain.h,
score/include/rtems/score/context.h,
score/include/rtems/score/coresem.h,
score/include/rtems/score/heap.h, score/include/rtems/score/interr.h,
score/include/rtems/score/isr.h, score/include/rtems/score/mpci.h,
score/include/rtems/score/mppkt.h,
score/include/rtems/score/objectmp.h,
score/include/rtems/score/stack.h,
score/include/rtems/score/states.h,
score/include/rtems/score/threadmp.h,
score/include/rtems/score/threadq.h, score/include/rtems/score/tod.h,
score/include/rtems/score/tqdata.h,
score/include/rtems/score/userext.h,
score/include/rtems/score/watchdog.h,
score/include/rtems/score/wkspace.h,
score/inline/rtems/score/chain.inl,
score/inline/rtems/score/coremutex.inl,
score/inline/rtems/score/coresem.inl,
score/inline/rtems/score/heap.inl,
score/inline/rtems/score/object.inl,
score/inline/rtems/score/thread.inl,
score/inline/rtems/score/tqdata.inl, score/macros/README,
score/src/heap.c, score/src/threadmp.c, score/src/threadready.c,
score/src/threadstartmultitasking.c: Improve generated Doxygen
output. Fix spelling and grammar errors in comments. Correct names of
some variables and propagate changes.
* score/cpu/no_cpu/rtems/score/cpu.h, score/include/rtems/debug.h,
score/include/rtems/seterr.h, score/include/rtems/system.h,
score/include/rtems/score/copyrt.h,
score/inline/rtems/score/coremsg.inl,
score/inline/rtems/score/heap.inl, score/inline/rtems/score/isr.inl,
score/inline/rtems/score/mppkt.inl,
score/inline/rtems/score/objectmp.inl,
score/inline/rtems/score/priority.inl,
score/inline/rtems/score/states.inl,
score/inline/rtems/score/threadmp.inl,
score/inline/rtems/score/tod.inl,
score/inline/rtems/score/userext.inl,
score/inline/rtems/score/watchdog.inl,
score/inline/rtems/score/wkspace.inl: Add Doxygen comments -- working
modifications which are not complete and may have broken code.
Committing so work and testing can proceed.
* score/Doxyfile, score/mainpage.h: New files.
the thread handler (IDLE), MPCI object (SYSI now MP Receive)
and initialize_executive_early (IO initialization). The SYSI task
no longer exists in a single processor configuration. This reduces
single processor Workspace requirements by a TCB and a stack which
is often larger than the minimum stack size. Moving the IO initialization
plus accompanying BSP hooks eliminated an initialization ordering problem
in which a global task could be created before the MPCI was initialized.
like signal dispatching.
