line option.
may suppress warnings.
erc32, imx, qoriq, etc.
* cpukit/include
* cpukit/libnetworking
* bsps/include
* bsps/@RTEMS_CPU@/include
order.
Update #3254.
The _RBTree_Find() is no longer used in the score. Move it to sapi and
make it rtems_rbtree_find(). Move corresponding types and support
functions to sapi.
Use the BSD <sys/tree.h> implementation since it is faster, more
flexible and uses less storage. See https://github.com/sebhub/rb-bench.
Simplify _RBTree_Insert() and _RBTree_Extract(). Remove more
superfluous NULL pointer checks. Change _RBTree_Is_root() to use only
the node. Add parent parameter to _RBTree_Sibling(). Delete
_RBTree_Grandparent() and _RBTree_Parent_sibling().
Add and use _RBTree_Direction().
Move implementation specific parts of rbtree.h and rbtree.inl into new
header file rbtreeimpl.h. The rbtree.h contains now only the
application visible API.
