path: root/cpukit/score/include/rtems/score/processormask.h (follow)
* Remove make preinstallChris Johns2018-01-251-290/+0
| | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | A speciality of the RTEMS build system was the make preinstall step. It copied header files from arbitrary locations into the build tree. The header files were included via the -Bsome/build/tree/path GCC command line option. This has at least seven problems: * The make preinstall step itself needs time and disk space. * Errors in header files show up in the build tree copy. This makes it hard for editors to open the right file to fix the error. * There is no clear relationship between source and build tree header files. This makes an audit of the build process difficult. * The visibility of all header files in the build tree makes it difficult to enforce API barriers. For example it is discouraged to use BSP-specifics in the cpukit. * An introduction of a new build system is difficult. * Include paths specified by the -B option are system headers. This may suppress warnings. * The parallel build had sporadic failures on some hosts. This patch removes the make preinstall step. All installed header files are moved to dedicated include directories in the source tree. Let @RTEMS_CPU@ be the target architecture, e.g. arm, powerpc, sparc, etc. Let @RTEMS_BSP_FAMILIY@ be a BSP family base directory, e.g. erc32, imx, qoriq, etc. The new cpukit include directories are: * cpukit/include * cpukit/score/cpu/@RTEMS_CPU@/include * cpukit/libnetworking The new BSP include directories are: * bsps/include * bsps/@RTEMS_CPU@/include * bsps/@RTEMS_CPU@/@RTEMS_BSP_FAMILIY@/include There are build tree include directories for generated files. The include directory order favours the most general header file, e.g. it is not possible to override general header files via the include path order. The "bootstrap -p" option was removed. The new "bootstrap -H" option should be used to regenerate the "headers.am" files. Update #3254.
* score: Include missing header fileSebastian Huber2017-09-221-0/+2
| | | | Update #3059.
* Add interrupt vector set/get affinitySebastian Huber2017-07-121-0/+25
| | | | Close #3071.
* score: Move processor affinity to Thread_ControlSebastian Huber2017-07-071-0/+2
| | | | Update #3059.
* score: Add some processor mask functionsSebastian Huber2017-07-061-0/+99
| | | | Update #3059.
* score: Add processor mask to/from cpu_set_tSebastian Huber2017-07-061-2/+50
| | | | Update #3059.
* score: Use <sys/bitset.h> for Processor_maskSebastian Huber2017-07-061-49/+42
| | | | | | | | Implement the Processor_mask via <sys/bitset.h>. Provide _Processor_mask_To_uint32_t() to enable its use in device specific routines, e.g. interrupt affinity register in an interrupt controller. Update #3059.
* SMP: Simplify SMP multicast actionsSebastian Huber2017-04-051-0/+31
* score: Add Processor_mask, etc.Sebastian Huber2016-03-041-0/+90
