Currently, the AArch64 BSPs have a hard time running on real hardware
without building the toolchain and the bsps with -mstrict-align in
multiple places. Configuring the MMU on these chips allows for unaligned
memory accesses for non-device memory which avoids requiring strict
alignment in the toolchain and in the BSPs themselves.
In writing this driver, it was found that the synchronous exception
handling code needed to be rewritten since it relied on clearing SCTLR_EL1 to
avoid thread stack misalignments in RTEMS_DEBUG mode. This is now
avoided by exactly preserving thread mode stack and flags and the new
implementation is compatible with the draft information provided on the
mailing list covering the Exception Management API.
Break out system register definitions and accessors so that they're
usable by other parts of RTEMS.
Ensure the stack remains aligned by keeping the context frame at a
multiple of 16 bytes. This avoids stack alignment exceptions which occur
when the stack pointer is not 16 byte aligned.
The __builtin_unreachable() cannot be used with current GCC versions to
tell the compiler that a function does not return to the caller, see:
https://gcc.gnu.org/bugzilla/show_bug.cgi?id=99151
Add a no return variant of _CPU_Context_switch() to avoid generation of
dead code in _Thread_Start_multitasking() if RTEMS was built with SMP
support enabled.
The _CPU_ISR_Is_enabled() function operates on ISR cookies and so must
mask off the appropriate status bits. This also fixes the naming of the
parameters of the _CPU_ISR_* functions to indicate use of ISR cookies
instead of interrupt enable/disable levels.
Overview
The errata is worked around in the kernel without requiring toolchain
modifications. It is triggered the JMPL/RETT return from trap instruction
sequence never generated by the compiler and. There are also other
conditions that must must be true to trigger the errata, for example the
instruction that the trap returns to has to be a JMPL instruction. The
errata can only be triggered if certain data is corrected by ECC
(inflicted by radiation), thus it can not be triggered under normal
operation. For more information see:
www.gaisler.com/notes
Affected RTEMS target BSPs:
* GR712RC
* UT699
* UT700/699E
The work around is enabled by defining __FIX_LEON3_TN0018 at build time.
After applying the following GCC patch, GCC will set the define when
compiling for an affected multilib:
* GR712RC (-mcpu=leon3 -mfix-gr712rc)
* UT700/UT699E (-mpcu=leon3 -mfix-ut700)
* UT699 (-mcpu=leon -mfix-ut699)
When building for another multilib and TN0018 is still required, it
is possible to enable it on the RTEMS kernel configure line using the
TARGET_CFLAGS (-D__FIX_LEON3FT_TN0018) or other by other means.
The following GCC patch sets __FIX_LEON3FT_TN0018 for the affected RTEMS
multilibs:
diff --git a/gcc/config/sparc/rtemself.h b/gcc/config/sparc/rtemself.h
index 6570590..ddec98c 100644
--- a/gcc/config/sparc/rtemself.h
+++ b/gcc/config/sparc/rtemself.h
@@ -33,6 +33,8 @@
builtin_assert ("system=rtems"); \
if (sparc_fix_b2bst) \
builtin_define ("__FIX_LEON3FT_B2BST"); \
+ if (sparc_fix_gr712rc || sparc_fix_ut700 || sparc_fix_ut699) \
+ builtin_define ("__FIX_LEON3FT_TN0018"); \
while (0)
Workaround Implementation
In general there are two approaches that the workaround uses:
A) avoid ECC restarting the RETT instruction
B) avoid returning from trap to a JMPL instruction
Where A) comes at a higher performance cost than B), so B) is used
where posssible. B) can be achived for certain returns from trap
handlers if trap entry is controlled by assembly, such as system calls.
A)
A special JMPL/RETT sequence where instruction cache is disabled
temporarily to avoid RETT containing ECC errors, and reading of RETT
source registers to "clean" them from incorrect ECC just before RETT
is executed.
B)
The work around prevents JMPL after system calls (TA instruction) and
modifies assembly code on return from traps jumping back to application
code. Note that for some traps the trapped instruction is always
re-executed and can therefore not trigger the errata, for example the
SAVE instruction causing window overflow or an float instruction causing
FPU disabled trap.
RTEMS SPARC traps workaround implementation:
NAME NOTE TRAP COMMENT
* window overflow 1 - 0x05 always returns to a SAVE
* window underflow 1 - 0x06 always returns to a RESTORE
* interrupt traps 2 - 0x10..1f special rett sequence workaround
* syscall 3 - 0x80 shutdown system - never returns
* ABI flush windows 2 - 0x83 special rett sequence workaround
* syscall_irqdis 4 - 0x89
* syscall_irqen 4 - 0x8A
* syscall_irqdis_fp 1 - 0x8B always jumps back to FP instruction
* syscall_lazy_fp_switch 5 - 0x04 A) jumps back to FP instruction, or to
B) _Internal_error() starting with SAVE
1) no workaround needed because trap always returns to non-JMPL instruction
2) workaround implemented by special rett sequence
3) no workaround needed because system call never returns
4) workaround implemented by inserting NOP in system call generation. Thus
fall into 1) when workaround is enabled and no trap handler fix needed.
5) trap handler branches into both 1) and returning to _Internal_error()
which starts with a SAVE and besides since it shuts down the system that
RETT should never be in cache (only executed once) so fix not necessary
in this case.
Any custom trap handlers may also have to be updated. To simplify that,
helper work around assembly code in macros are available in a separate
include file <libcpu/grlib-tn-0018.h>.
Close #4155.
Close #4336.
Update #4336.
Update #4336.
Run with stack alignment faults enabled under RTEMS_DEBUG to catch any
stack misalignments early. This makes it easier to track them down
should they ever occur.
The Per_CPU_Control::isr_dispatch_disable is a 32-bit integer.
Close #4206.
Clarify CPU_STACK_ALIGNMENT requirements in no_cpu port. Add static
assertion to enforce CPU_STACK_ALIGNMENT requirements.
Rename _Nios2_ISR_Dispatch_with_shadow_non_preemptive() in
_Nios2_ISR_Dispatch_with_shadow_register_set(). Remove
_Nios2_ISR_Dispatch_with_shadow_preemptive().
Use _Thread_Do_dispatch() in
_Nios2_ISR_Dispatch_with_shadow_non_preemptive().
Update #4214.
This allows the BSP to override this function.
The thread dispatch disabled level moved to _Per_CPU_Information some
time ago.
Update #4202.
Update #4202.
Update #4202.
Somehow the table index has been missing in the latest patch version.
With that, the configuration for the first region has been applied
multiple times.
Update #4180
Update #4202.
This resolves a warning in the exception frame dump for AArch64 relating
to a missized printf format specifier.
Modify the MPU functions of the stm32h7 BSP to be table based and
available for all ARMV7M BSPs.
Update #4180
This ensures that the saved SP register is sized appropriately depending
on the chosen ABI and prevents a warning in the libmisc stack checker.
Update #4171.
Update #4171.
Update #4171.
Clarify Doxygen comments. Fix formatting.
Update #4171.
Add a workaround for Cortex-A9 Errata 845369: Under Very Rare Timing
Circumstances Transition into Streaming Mode Might Create Data Corruption.
Update #4115.
Provide RTEMS_NO_RETURN also in case RTEMS_DEBUG is defined to prevent errors
like this:
error: no return statement in function returning non-void [-Werror=return-type]
Use C11 and C++11 standard means to declare a no-return function.
Close #4122.
This adds a CPU port for AArch64(ARMv8) with support for exceptions and
interrupts.
Debug output can be added to user-defined fatal error handlers.
Including <stdio.h> in <rtems/score/cpu.h> breaks libbsd.
In a multi-processor system we must broadcast the TLB maintenance operation to
the Inner Shareable domain to ensure that the other processors update their TLB
caches accordingly.
Close #4068.
Closes #4076.
Prefer macros with a proper namespace.
Make sure that the esp is restored before the eflags register.
When the init task is initially restored, system interrupts are activated when the
eflags register is loaded.
If the esp register still points to an address in the interrupt stack
area (from early system initlization) the ISR might overwrite its own
stack.
Closes #4031
Due to an unmaintained toolchain (internal errors in GCC, no FSF GDB
integration) the Epiphany architecture was obsoleted in RTEMS 5.1.
Update #3941.
Update #3943.
Update #4018.
This introduces the CPU_USE_LIBC_INIT_FINI_ARRAY define for use by CPU
ports to determine which global constructor and destructor methods are
used instead of placing architecture defines where they shouldn't be.
Close #4018
