path: root/cpukit/score/cpu/riscv (follow)
* build: Remove old build systemSebastian Huber2021-09-211-11/+0
| | | | | Close #3250. Close #4081.
* score: Canonicalize _CPU_Fatal_halt()Sebastian Huber2021-07-282-2/+2
| | | | | | | | Move _CPU_Fatal_halt() declaration to <rtems/score/cpuimpl.h> and make sure it is a proper declaration of a function which does not return. Fix the type of the error code. If necessary, add the implementation to cpu.c. Implementing _CPU_Fatal_halt() as a function makes it possible to wrap this function for example to fully test _Terminate().
* score: Remove processor event broadcast/receiveSebastian Huber2021-07-281-10/+0
| | | | | | Remove _CPU_SMP_Processor_event_broadcast() and _CPU_SMP_Processor_event_receive(). These functions are hard to use since they are subject to the lost wake up problem.
* score: Remove _CPU_Initialize_vectors()Sebastian Huber2021-06-241-2/+0
| | | | | | | This CPU port macro was not used. Since the _ISR_Vector_table[] is statically allocated, CPU ports could initialize this table in _CPU_Initialize() if necessary. Remove _CPU_Initialize_vectors() to simplify the CPU port interface.
* score: Add _CPU_Context_switch_no_return()Sebastian Huber2021-05-182-0/+7
| | | | | | | | | | | The __builtin_unreachable() cannot be used with current GCC versions to tell the compiler that a function does not return to the caller, see: https://gcc.gnu.org/bugzilla/show_bug.cgi?id=99151 Add a no return variant of _CPU_Context_switch() to avoid generation of dead code in _Thread_Start_multitasking() if RTEMS was built with SMP support enabled.
* rtems: Improve RTEMS_NO_RETURN attributeSebastian Huber2020-10-101-4/+2
| | | | | | | | | | | Provide RTEMS_NO_RETURN also in case RTEMS_DEBUG is defined to prevent errors like this: error: no return statement in function returning non-void [-Werror=return-type] Use C11 and C++11 standard means to declare a no-return function. Close #4122.
* score: Add CPU_USE_LIBC_INIT_FINI_ARRAYKinsey Moore2020-06-301-0/+2
| | | | | | | | This introduces the CPU_USE_LIBC_INIT_FINI_ARRAY define for use by CPU ports to determine which global constructor and destructor methods are used instead of placing architecture defines where they shouldn't be. Close #4018
* Regenerate headers.amSebastian Huber2019-11-291-0/+1
* riscv: preliminarily support for libdlHesham Almatary2019-11-121-0/+144
| | | | Support for targets compiled with -fno-pic and -mno-relax
* doxygen: score: Add RISC-V CPU architecture groupAndreas Dachsberger2019-04-024-1/+26
| | | | Update #3706.
* score: Rename ScoreCPU Doxygen groupSebastian Huber2019-03-261-1/+1
| | | | Update #3706.
* Remove superfluous <rtems/system.h> includesSebastian Huber2019-03-141-1/+0
* Remove explicit file names from @fileSebastian Huber2019-02-283-3/+3
| | | | | | This makes the @file documentation independent of the actual file name. Update #3707.
* riscv: Fix misaligned access in context validateSebastian Huber2019-02-021-1/+1
* riscv: add griscv bspJiri Gaisler2019-01-221-4/+1
| | | | Update #3678.
* grlib: use cpu-independent routines for uncached accessJiri Gaisler2019-01-223-0/+83
| | | | Update #3678.
* riscv: Enable robust thread dispatchSebastian Huber2019-01-091-0/+3
| | | | | | | It must be enabled, since the context switch code does not save/restore the interrupt status. Update #3433.
* build: Include header.am in cpukit/Makefile.amSebastian Huber2018-10-102-14/+7
| | | | | Include all cpukit/*/header.am files in cpukit/Makefile.am. This gets rid of all subtree Makefile.am and the sudirs hack.
* build: Merge score/cpu/*/Makefile.amSebastian Huber2018-10-101-12/+0
* build: Remove specialized CPPFLAGSSebastian Huber2018-10-091-1/+0
* score: Remove CPU_PROVIDES_IDLE_THREAD_BODYSebastian Huber2018-10-051-1/+0
| | | | | | | Remove the CPU_PROVIDES_IDLE_THREAD_BODY option to avoid unnecessary conditional compilation. Close #3539.
* score: Remove CPU_PARTITION_ALIGNMENTSebastian Huber2018-08-021-2/+0
| | | | | | | | | | | | | | Use the CPU_SIZEOF_POINTER alignment instead. The internal alignment requirement is defined by the use of Chain_Node (consisting of two pointers) to manage the free chain of partitions. It seems that previously the condition CPU_PARTITION_ALIGNMENT >= sizeof(Chain_Node) was true on all CPU ports. Now, we need an additional check. Update #3482.
* riscv: Fix CPU_ALIGNMENTSebastian Huber2018-08-021-1/+3
| | | | Update #3433.
* riscv: Rework CPU counter supportSebastian Huber2018-07-274-5/+91
| | | | Update #3433.
* riscv: Add CLINT and PLIC supportSebastian Huber2018-07-251-5/+45
| | | | | | The CLINT and PLIC need some per-processor state. Update #3433.
* riscv: Use wfi instruction for idle taskSebastian Huber2018-07-252-12/+3
| | | | Update #3433.
* riscv: Rework exception handlingSebastian Huber2018-07-256-144/+54
| | | | | | | | | | | Remove _CPU_ISR_install_raw_handler() and _CPU_ISR_install_vector() functions. Applications can install an exception handler via the fatal error handler to handle synchronous exceptions. Handle interrupt exceptions via _RISCV_Interrupt_dispatch() which must be provided by the BSP. Update #3433.
* riscv: New CPU_Exception_frameSebastian Huber2018-07-254-64/+203
| | | | | | | Use the CPU_Interrupt_frame for the volatile context. Add non-volatile registers and extra state on top of it. Update #3433.
* riscv: Add exception codesSebastian Huber2018-07-251-0/+39
| | | | Update #3433.
* score: Add _CPU_Instruction_illegal()Sebastian Huber2018-07-231-0/+5
| | | | | | | | On some architectures/simulators it is difficult to provoke an exception with misaligned or illegal data loads. Use an illegal instruction instead. Update #3433.
* score: Add _CPU_Instruction_no_operation()Sebastian Huber2018-07-201-0/+5
| | | | | This helps to reduce the use of architecture-specific defines throughout the code base.
* score: Move context validation declarationsSebastian Huber2018-07-202-4/+4
| | | | | | | The context validation support functions _CPU_Context_validate() and _CPU_Context_volatile_clobber() are used only by one test program (spcontext01). Move the function declarations to the CPU port implementation header file.
* score: Remove obsolete CPU port definesSebastian Huber2018-07-201-4/+0
* riscv: Add LADDR assembler defineSebastian Huber2018-07-062-2/+12
| | | | | | | An address must be loaded to a register according to the code model. Add LADDR define for use in assembler code. Update #3433.
* riscv: Implement CPU counterSebastian Huber2018-07-062-2/+16
| | | | Update #3433.
* riscv: Clear reservationsSebastian Huber2018-07-055-6/+25
| | | | | | | See also RISC-V User-Level ISA V2.3, comment in section 8.2 "Load-Reserved/Store-Conditional Instructions". Update #3433.
* riscv: Fix fcsr initializationSebastian Huber2018-07-022-1/+19
| | | | Update #3433.
* riscv: Fix SMP context switch supportSebastian Huber2018-06-291-2/+2
| | | | Update #3433.
* riscv: Add SMP context switch supportSebastian Huber2018-06-291-0/+47
| | | | Update #3433.
* riscv: Add floating-point supportSebastian Huber2018-06-298-50/+538
| | | | Update #3433.
* riscv: Fix global constructionSebastian Huber2018-06-291-4/+5
| | | | Update #3433.
* riscv: Add TLS supportSebastian Huber2018-06-292-0/+9
| | | | Update #3433.
* riscv: Remove dead codeSebastian Huber2018-06-291-41/+1
| | | | Update #3433.
* riscv: Optimize context switch and interruptsSebastian Huber2018-06-296-174/+255
| | | | | | | | Save/restore non-volatile registers in _CPU_Context_switch(). Save/restore volatile registers in _ISR_Handler(). Update #3433.
* riscv: Fix _CPU_Context_Initialize() prototypeSebastian Huber2018-06-292-12/+12
| | | | Update #3433.
* riscv: Fix interrupt save/restoreSebastian Huber2018-06-291-1/+1
| | | | Update #3433.
* riscv: Implement _CPU_Context_validate()Sebastian Huber2018-06-292-160/+168
| | | | Update #3433.
* riscv: Make some CPU port defines visible to asmSebastian Huber2018-06-292-37/+49
| | | | | | Move SREG and LREG assembler defines to <rtems/score/asm.h>. Update #3433.
* riscv: Implement _CPU_Context_volatile_clobber()Sebastian Huber2018-06-292-16/+16
| | | | Update #3433.
* riscv: Remove mstatus from thread contextSebastian Huber2018-06-294-27/+14
| | | | | | | | | | The mstatus register contains no thread-specific state which must be saved/restored during a context switch. Machine interrupts (MIE) must be enabled during a context switch. Create separate CPU_Interrupt_frame structure. Update #3433.
