This CPU port macro was not used. Since the _ISR_Vector_table[] is statically
allocated, CPU ports could initialize this table in _CPU_Initialize() if
necessary. Remove _CPU_Initialize_vectors() to simplify the CPU port
interface.
The __builtin_unreachable() cannot be used with current GCC versions to
tell the compiler that a function does not return to the caller, see:
https://gcc.gnu.org/bugzilla/show_bug.cgi?id=99151
Add a no return variant of _CPU_Context_switch() to avoid generation of
dead code in _Thread_Start_multitasking() if RTEMS was built with SMP
support enabled.
Provide RTEMS_NO_RETURN also in case RTEMS_DEBUG is defined to prevent errors
like this:
error: no return statement in function returning non-void [-Werror=return-type]
Use C11 and C++11 standard means to declare a no-return function.
Close #4122.
This introduces the CPU_USE_LIBC_INIT_FINI_ARRAY define for use by CPU
ports to determine which global constructor and destructor methods are
used instead of placing architecture defines where they shouldn't be.
Close #4018
Support for targets compiled with -fno-pic and -mno-relax
Update #3706.
Update #3706.
This makes the @file documentation independent of the actual file name.
Update #3707.
Update #3678.
Update #3678.
It must be enabled, since the context switch code does not save/restore
the interrupt status.
Update #3433.
Include all cpukit/*/header.am files in cpukit/Makefile.am. This gets
rid of all subtree Makefile.am and the sudirs hack.
Remove the CPU_PROVIDES_IDLE_THREAD_BODY option to avoid unnecessary
conditional compilation.
Close #3539.
Use the CPU_SIZEOF_POINTER alignment instead. The internal alignment
requirement is defined by the use of Chain_Node (consisting of two
pointers) to manage the free chain of partitions.
It seems that previously the condition
CPU_PARTITION_ALIGNMENT >= sizeof(Chain_Node)
was true on all CPU ports. Now, we need an additional check.
Update #3482.
Update #3433.
Update #3433.
The CLINT and PLIC need some per-processor state.
Update #3433.
Update #3433.
Remove _CPU_ISR_install_raw_handler() and _CPU_ISR_install_vector()
functions. Applications can install an exception handler via the fatal
error handler to handle synchronous exceptions.
Handle interrupt exceptions via _RISCV_Interrupt_dispatch() which must
be provided by the BSP.
Update #3433.
Use the CPU_Interrupt_frame for the volatile context. Add non-volatile
registers and extra state on top of it.
Update #3433.
Update #3433.
On some architectures/simulators it is difficult to provoke an
exception with misaligned or illegal data loads. Use an illegal
instruction instead.
Update #3433.
This helps to reduce the use of architecture-specific defines throughout
the code base.
The context validation support functions _CPU_Context_validate() and
_CPU_Context_volatile_clobber() are used only by one test program
(spcontext01). Move the function declarations to the CPU port
implementation header file.
An address must be loaded to a register according to the code model.
Add LADDR define for use in assembler code.
Update #3433.
Update #3433.
See also RISC-V User-Level ISA V2.3, comment in section 8.2
"Load-Reserved/Store-Conditional Instructions".
Update #3433.
Update #3433.
Update #3433.
Update #3433.
Update #3433.
Update #3433.
Update #3433.
Update #3433.
Save/restore non-volatile registers in _CPU_Context_switch().
Save/restore volatile registers in _ISR_Handler().
Update #3433.
Update #3433.
Update #3433.
Update #3433.
Move SREG and LREG assembler defines to <rtems/score/asm.h>.
Update #3433.
Update #3433.
The mstatus register contains no thread-specific state which must be
saved/restored during a context switch. Machine interrupts (MIE) must
be enabled during a context switch.
Create separate CPU_Interrupt_frame structure.
Update #3433.
The RISC-V psABI
https://github.com/riscv/riscv-elf-psabi-doc/blob/master/riscv-elf.md
does not mention that this is a frame pointer.
Update #3433.
Update #3433.
Do not clear the complete thread context. Initialize only the necessary
members. The Context_Control::is_executing member must be preserved
across _CPU_Context_Initialize() calls.
Update #3433.
