Rename bsp_smp_initialize() into _CPU_SMP_Initialize() since every CPU
port must supply this function.
The instructions to get the processor current index have no
side-effects.
Delete _CPU_Context_switch_to_first_task_smp() and use
_CPU_Context_restore() instead.
Tested and implemented on ARM, m68k, PowerPC and SPARC. Other
architectures need more work.
The r2 may be used for thread-local storage.
Add CPU port specific per-CPU control.
Rename to _CPU_SMP_Processor_event_receive().
Rename to _CPU_SMP_Processor_event_broadcast().
Delete bsp_smp_interrupt_cpu().
Add and use _SMP_Get_current_processor() and
rtems_smp_get_current_processor().
Change type of current processor index from int to uint32_t to match
_SMP_Processor_count type.
Use the right context.
Add CPU port type CPU_Exception_frame and function
_CPU_Exception_frame_print().
The CPU ports of avr, bfin, h8300, lm32, m32c, m32r, m68k, nios2, sh,
sparc64, and v850 use an empty default implementation of
Add rtems_exception_frame and rtems_exception_frame_print().
Add RTEMS_FATAL_SOURCE_EXCEPTION for CPU exceptions. Use rtems_fatal()
with source RTEMS_FATAL_SOURCE_EXCEPTION in CPU ports of i386, powerpc,
and sparc for unexpected exceptions.
Add third parameter to RTEMS_BSP_CLEANUP_OPTIONS() which controls the
BSP_PRINT_EXCEPTION_CONTEXT define used in the default
bsp_fatal_extension().
Add test sptests/spfatal26.
The powerpc port uses now a unified CPU_Exception_frame. This resulted
in a CPU_Exception_frame layout change for the MPC5XX.
Add and use new CPU port define CPU_SIZEOF_POINTER. It must be an
integer literal that can be used by the assembler. This value will be
used to calculate offsets of structure members. These offsets will be
used in assembler code.
The size of a pointer is part of the application binary interface (ABI)
and thus independent of the actual programming language. The compiler
will provide defines to determine the current ABI. We use these defines
to select the appropriate CPU_SIZEOF_POINTER value.
Static assertions in the new file "cpukit/score/src/percpuasm.c" will
ensure that the value of CPU_SIZEOF_POINTER is consistent with the
current compiler settings. Also the offset values used by assembler
code are verfied.
This function is only used if CPU_HAS_HARDWARE_INTERRUPT_STACK == TRUE.
_CPU_ISR_Initialize
PowerPC cores with the SPE (Signal Processing Extension) have 64-bit
general-purpose registers. The SPE context switch code has been merged
with the standard context switch code. The context switch may use cache
operations to increase the performance. It will be ensured that the
context is 32-byte aligned (PPC_DEFAULT_CACHE_LINE_SIZE). This
increases the overall memory size of the context area in the thread
control block slightly. The general-purpose registers GPR2 and GPR13
are no longer part of the context. The BSP must initialize these
registers during startup (usually initialized by the __eabi() function).
The new BSP option BSP_USE_DATA_CACHE_BLOCK_TOUCH can be used to enable
the dcbt instruction in the context switch.
The new BSP option BSP_USE_SYNC_IN_CONTEXT_SWITCH can be used to enable
sync and isync instructions in the context switch. This should be not
necessary in most cases.
In particular CPU_INTERRUPT_NUMBER_OF_VECTORS and
CPU_INTERRUPT_MAXIMUM_VECTOR_NUMBER are only used on
Simple Vectored Architectures, so do not depend on
them being defined. This disables as much as possible
that is specific to the Simple Vectored Model and
not expected to be used on architectures which use
the Programmable Interrupt Controller model for
interrupt handler vectoring.
PR 1914/cpukit
* rtems/score/cpu.h: Select timestamp implementation.
* rtems/score/cpu.h: Add more context access functionality. Needed to
get GDB debugger hooks working.
* rtems/score/cpu.h: Added SPE support to CPU context.
* rtems/powerpc/registers.h, rtems/score/cpu.h:
* rtems/score/cpu.h: Add RTEMS_COMPILER_NO_RETURN_ATTRIBUTE to
_CPU_Context_restore() because it does not return. Telling GCC this
avoids generation of dead code.
PR 1635/cpukit
* rtems/score/cpu.h, rtems/score/types.h: Refactoring of priority
handling, to isolate the bitmap implementation of priorities in the
supercore so that priority management is a little more modular. This
change is in anticipation of scheduler implementations that can
select how they manage tracking priority levels / finding the highest
priority ready task. Note that most of the changes here are simple
renaming, to clarify the use of the bitmap-based priority management.
* rtems/new-exceptions/cpu.h: Removed file.
* Makefile.am, preinstall.am: Reflect change above.
* rtems/score/cpu.h: Include <rtems/score/types.h> first. Added
contents of <rtems/new-exceptions/cpu.h>.
* rtems/score/types.h: Use <rtems/score/basedefs.h> header file.
* score/cpu/powerpc/rtems/score/cpu.h: Added space for non-
volatile AltiVec registers to context struct. Added declaration
for AltiVec-related routines to be implemented by CPU/BSP
support.
* rtems/score/cpu.h: Changed fpscr field to an integer type in
Context_Control_fp. Fixed warnings in PPC_Set_timebase_register().
Changed _CPU_Context_Initialize_fp() to initialize all fields and
avoid floating-point instructions.
* rtems/score/powerpc.h: Removed PPC_INIT_FPSCR define.
* rtems/new-exceptions/cpu.h, rtems/score/cpu.h: Eliminate
_CPU_Thread_dispatch_pointer and passing address of _Thread_Dispatch
to _CPU_Initialize. Clean up comments.
* rtems/score/cpu.h: Move extern of bsp_clicks_per_usec so it is not
nested inside braces.
* cpukit/score/cpu/powerpc/rtems/new-exceptions/cpu.h,
cpukit/score/cpu/powerpc/rtems/score/cpu.h,
cpukit/score/cpu/powerpc/rtems/score/powerpc.h:
Removed all macro definitions which depended on
the compiler defining a PPC CPU-model dependent
symbol.
Macros which were not used by cpukit have been
moved to libcpu/powerpc/rtems/powerpc/powerpc.h.
* rtems/score/cpu.h: Add _CPU_Context_Get_SP() for stack check utility.
* rtems/powerpc/registers.h, rtems/score/cpu.h: Sweep to make sure grep
for COPYRIGHT passes.
* rtems/new-exceptions/cpu.h, rtems/old-exceptions/cpu.h,
rtems/score/cpu.h: Move interrupt_stack_size field from CPU Table to
Configuration Table. Eliminate CPU Table from all ports. Delete
references to CPU Table in all forms.
* rtems/score/cpu.h: Added comment that GDB patch sim/2376
is needed for reading the time-base with the new (more
portable) method.
* rtems/score/cpu.h: Wonderful bookE doesn't have mftb/mftbu;
( CPU_Get_timebase_low() ) they only define the TBRU/TBRL SPRs
so we use these. Should work on all CPUs.
rtems/score/cpu.h: Eliminate PowerPC specific elements from the CPU
Table. They have been replaced with variables named bsp_XXX as
needed.
* rtems/score/cpu.h: Remove CPU_HAS_OWN_HOST_TO_NETWORK_ROUTINES.
Eliminate evil casts.
* rtems/score/cpu.h: Because gcc implicitly uses floating point turn on
floating point for all threads if there is a hardware FPU.
rtems/score/cpu.h: Part of a large patch to improve Doxygen output.
As a side-effect, grammar and spelling errors were corrected, spacing
errors were address, and some variable names were improved.
CPU_IDLE_TASK_IS_FP, CPU_SOFTWARE_FP): New.
