brains GmbH.
Updates #4625.
Updates #3053.
Rename Classic API top-level group from Classic to RTEMSImplClassic.
Use RTEMSImplClassic as a prefix for the subgroups. Change the group
names to be in line with the API group names. Use common phrases for
the group brief descriptions.
Update #3706.
#ifdef HAVE_CONFIG_H
#include "config.h"
#endif
Update #3598.
Uniformly use *_Get() to get an object by identifier with a lock
context.
Remove the object location parameter.
This function is superfluous due to the introduction of fine grained
locking.
Remove _Thread_Acquire() and _Thread_Acquire_for_executing(). Add
utility functions for the default thread lock. Use the default thread
lock for the RTEMS events. There is no need to disable thread
dispatching and a Giant acquire in _Event_Timeout() since this was
already done by the caller.
Update #2273.
Use the ISR lock of the thread object to protect the event state and
use the Giant lock only for the blocking operations.
Update #2273.
Move implementation specific parts of thread.h and thread.inl into new
header file threadimpl.h. The thread.h contains now only the
application visible API.
Remove superfluous header file includes from various files.
Move implementation specific parts of event.h, event.inl, eventset.h and
eventset.inl into new header file eventimpl.h. The event.h contains now
only the application visible API.
Add and use _Objects_Put_without_thread_dispatch(). These two functions
pair with the _Objects_Get() function. This helps to introduce object
specific SMP locks to avoid lock contention.
System events are similar to normal events. They offer a second set of
events. These events are intended for internal RTEMS use and should not
be used by applications (with the exception of the transient system
event).
