* | cpukit/rtems/src/[s-z]*.c: Change license to BSD-2 | Joel Sherrill | 2022-02-28 | 1 | -3/+22 |
| | | | | Updates #3053. | ||||
* | rtems: Canonicalize Doxygen @file comments | Sebastian Huber | 2020-12-02 | 1 | -3/+5 |
| | | | | | | Use common phrases for the file brief descriptions. Update #3706. | ||||
* | termios: Add Capability to Generate SIGINTR and SIGQUIT | Joel Sherrill | 2019-10-08 | 1 | -0/+1 |
| | | | | | | | | | | | | | | This patch adds the ability for termios to send SIGINTR on receipt of VINTR and SIGQUIT for VKILL and return -1/EINTR from read() on a termios channel. Importantly, this patch does not alter the default behavior or force POSIX signal code in just because termios is used. The application must explicitly enable the POSIX behavior of generating a signal upon receipt of these characters. This is discussed in the POSIX standard: https://pubs.opengroup.org/onlinepubs/9699919799/basedefs/V1_chap11.html Closes #3800. | ||||
* | rtems: Move _Status_Object_name_errors_to_status | Sebastian Huber | 2018-06-05 | 1 | -0/+66 |
Move _Status_Object_name_errors_to_status to a separate file to avoid a dependency on errno. Dependencies to errno are hard to be removed by the linker garbage collection. |
