Install the network headers only if --enable-networking is specified.
Update #3254.
line option.
may suppress warnings.
erc32, imx, qoriq, etc.
* cpukit/include
* cpukit/libnetworking
* bsps/include
* bsps/@RTEMS_CPU@/include
order.
Update #3254.
for details.
* libnetworking/Makefile.am: Reformat.
* librpc/Makefile.am: Reformat.
* librpc/include/rpc/clnt_soc.h, librpc/include/rpc/svc_soc.h:
New (Partial update from FreeBSD).
* librpc/Makefile.am: Reflect changes above.
* librpc/include/rpc/des.h: Remove (Unused, unsupported).
* librpc/src/rpc/auth_des.c,
librpc/src/rpc/auth_time.c,
librpc/src/rpc/authdes_prot.c,
librpc/src/rpc/clnt_unix.c,
librpc/src/rpc/crypt_client.c,
librpc/src/rpc/des_crypt.c,
librpc/src/rpc/des_soft.c,
librpc/src/rpc/getpublickey.c,
librpc/src/rpc/key_call.c,
librpc/src/rpc/key_prot_xdr.c,
librpc/src/rpc/svc_auth_des.c,
librpc/src/rpc/svc_unix.c: Remove (Unused, obsolete).
* librpc/src/rpc/PSD.doc/rpc.prog.ms,
librpc/src/rpc/PSD.doc/rpcgen.ms,
librpc/src/rpc/PSD.doc/nfs.rfc.ms,
librpc/src/rpc/PSD.doc/xdr.rfc.ms,
librpc/src/rpc/PSD.doc/rpc.rfc.ms,
librpc/src/rpc/PSD.doc/xdr.nts.ms:
* librpc/Makefile.am: Split preinstallation rules in to separate
preinstall.am-files.
* librpc/preinstall.am: New (Generated from corresponding Makefile.am).
* librpc/include/rpc/clnt_stat.h, librpc/include/rpc/rpcent.h:
New (From FreeBSD).
* librpc/include/rpc/rpc.h: Partial update from FreeBSD.
* httpd/Makefile.am, itron/Makefile.am, libblock/Makefile.am,
libcsupport/Makefile.am, libfs/Makefile.am, libmisc/Makefile.am,
libnetworking/Makefile.am, librpc/Makefile.am, posix/Makefile.am,
rtems/Makefile.am, sapi/Makefile.am, score/Makefile.am:
Eliminate CFLAGS_OPTIMIZE_V.
* automake/compile.am, httpd/Makefile.am, itron/Makefile.am,
libblock/Makefile.am, libcsupport/Makefile.am, libfs/Makefile.am,
libmisc/Makefile.am, libnetworking/Makefile.am, librpc/Makefile.am,
posix/Makefile.am, rtems/Makefile.am, sapi/Makefile.am,
score/Makefile.am, wrapup/Makefile.am:
Remove build-variant support.
* Makefile.am: Re-add dirstamps to PREINSTALL_FILES.
Add PREINSTALL_FILES to CLEANFILES.
* Makefile.am: Include compile.am, again.
Put man-pages into EXTRA_DIST to work around automake not
distributing conditionally installed *_MANS.
Distribute include/rpcsvc.
* Makefile.am: Add libs to CLEANFILES
Set lib*_g_a_SOURCES = lib*_a_SOURCES.
* Makefile.am: Build lib*$(LIB_VARIANT).a instead of
$(ARCH)/lib*.a.
* Makefile.am: Build library using EXTRA_LIBRARIES and automake rules.
* Makefile.am: Use mkdir_p. Remove dirs from PRE/TMPINSTALL_FILES.
* Makefile.am: Add $(dirstamp) to compilation rules.
* Makefile.am: Add $(dirstamp) to preinstallation rules.
* src/rpc/Makefile.am, src/xdr/Makefile.am, src/Makefile.am:
Removed.
* Makefile.am: Merge-in src/rpc/Makefile.am, src/xdr/Makefile.am,
src/Makefile.am.
Various fixes. Reformat.
* configure.ac: Remove (Merged-in into ../configure.ac)
* Makefile.am, include/Makefile.am, src/Makefile.am,
src/rpc/Makefile.am, src/xdr/Makefile.am:
AC_CONFIG_AUX_DIR(../../../..).
Remove RTEMS_CANONICAL_HOST.
Use RTEMS_ENV_RTEMSCPU.
Add AC_PROG_RANLIB.
* include/rpc/Makefile.am: Include $(top_srcdir)/../automake/*.am.
* include/rpcsvc/Makefile.am: Include $(top_srcdir)/../automake/*.am.
ACLOCAL_AMFLAGS = -I ../aclocal.
* src/rpc/PSD.doc/Makefile.am: Include $(top_srcdir)/../automake/*.am.
* src/rpc/Makefile.am: Include $(top_srcdir)/../automake/*.am.
* src/xdr/Makefile.am: Include $(top_srcdir)/../automake/*.am.
* include/rpc/Makefile.am: Remove AUTOMAKE_OPTIONS.
* include/rpcsvc/Makefile.am: Remove AUTOMAKE_OPTIONS.
* src/rpc/PSD.doc/Makefile.am: Remove AUTOMAKE_OPTIONS.
* src/rpc/Makefile.am: Remove AUTOMAKE_OPTIONS.
* src/xdr/Makefile.am: Remove AUTOMAKE_OPTIONS.
* src/rpc/Makefile.am, src/xdr/Makefile.am: Include compile.am
mkdir c/src/librpc
mkdir c/src/librpc/src
mkdir c/src/librpc/include
rm -rf c/src/lib/librpc
rm -rf c/src/lib/include/rpc
in the required order .
# make[5]: Entering directory
# mips64orion-rtems-gcc -v
# mips64orion-rtems-ld -v
