Update #3850
#ifdef HAVE_CONFIG_H
#include "config.h"
#endif
There was a race conditon in the reference counting of file descriptors
during a close() operation. After the call to the close handler, the
rtems_libio_free() function cleared the flags to zero. However, at this
point in time there may still exist some holders of the file descriptor.
With RTEMS_DEBUG enabled this could lead to failed assertions in
rtems_libio_iop_drop().
Change the code to use only atomic read-modify-write operations on the
rtems_libio_iop::flags.
This makes the @file documentation independent of the actual file name.
Update #3707.
Update #3530.
Update #3533.
Add and use <machine/rtems-bsd-kernel-space.h> and
<machine/rtems-bsd-user-space.h> similar to the libbsd to avoid command
line defines and defines scattered throught the code base.
Simplify cpukit/libnetworking/Makefile.am.
Update #3375.
Move FTP client filesystem to separate library libftpfs.a.
Update #3419.
Move TFTP client filesystem to separate library libtftpfs.a.
Conditionally use legacy network stack features, e.g. BOOTP support.
Update #3419.
Update #2843.
Update #3117.
Update #3182.
Replace rtems_libio_check_fd(), rtems_libio_iop(),
rtems_libio_check_open() and rtems_libio_check_permissions()
combinations with new LIBIO_GET_IOP() and LIBIO_GET_IOP_WITH_ACCESS()
macros.
Update #3132.
Update #3132.
Update #3132.
Update #3132.
Update #3132.
Update #3132.
Added a mmap file handler to struct _rtems_filesystem_file_handlers_r.
Updated each file handler object to support the default mmap handler.
Updated mmap() to call the mmap handler for MAP_SHARED.
Added a mmap file handler for shm
Added support for MAP_ANON in mmap().
Updates #2859
Close #2877.
Move legacy network stack implementation specifics to
<rtems/rtems_bsdnet_internal.h>. Include missing header files. Add
interface flags compatibility.
Update #2833.
Update #2833.
Move RTEMS specifics to <rtems/rtems_bsdnet.h>.
Introduce rtems_tap_ifreq. The interface tap support is RTEMS-specific
and only available in the legacy network stack.
Update #2833.
Some kernel-space header expect that <sys/param.h> is present.
Update #2833.
Update #2833.
Do not use the MSIZE for the legacy network stack. Instead use
_SYS_MBUF_LEGACY_MSIZE.
Update #2833.
Use the Thread_Control::resource_count for the no protocol mutexes.
Merge the no protocol and priority inherit CORE mutex seize/surrender
operations.
Introduce Thread_queue_Lock_context to contain the context necessary for
thread queue lock and thread wait lock acquire/release operations to
reduce the Thread_Control size.
Clock disciplines may be WATCHDOG_RELATIVE, WATCHDOG_ABSOLUTE,
or WATCHDOG_NO_TIMEOUT. A discipline of WATCHDOG_RELATIVE with
a timeout of WATCHDOG_NO_TIMEOUT is equivalent to a discipline
of WATCHDOG_NO_TIMEOUT.
updates #2732
Close #2748.
Import the <arpa/inet.h> from current FreeBSD. Necessary due to changes
in <netinet/in.h>. Remove BSD hack from <arpa/inet.h>.
Clean up problems with htonl(). These functions are defined in
<arpa/inet.h>. This lead to some problems because they are defined in
<rtems/endian.h> too. Add NTOHL, ... to
Import the <netinet/in.h> from current FreeBSD. This allows to build
some current software (e.g. libressl).
Add legacy support like
* prototype for in_cksum(),
* IPPORT_USERRESERVED,
* deprecated IPCTL_RT* defines,
* ip_fw_chk_t and ip_fw_ctl_t,
* ip_nat_... (IP NAT hooks), and
* IP_NAT option for get/setsockopt()
to new <rtems/rtems_netinet_in.h>.
Move prototypes of non-portable _get*by*name/addr and _set/end*ent
functions. This makes it easier to update <netdb.h>.
Provide dedicated seize and surrender methods for inherit priority
mutexes. This eliminates CORE_mutex_Attributes.
Add CORE_recursive_mutex_Control and CORE_ceiling_mutex_Control to avoid
the run-time evaluation of attributes to figure out how a particular
mutex methods should behave. Start with the no protocol variants. This
eliminates the CORE_MUTEX_DISCIPLINES_FIFO and
CORE_MUTEX_DISCIPLINES_PRIORITY disciplines.
Add _Thread_queue_Context_set_MP_callout() to simplify
_Thread_queue_Context_initialize(). This makes it possible to more
easily add additional fields to Thread_queue_Context.
Unify the status codes of the Classic and POSIX API to use the new enum
Status_Control. This eliminates the Thread_Control::Wait::timeout_code
field and the timeout parameter of _Thread_queue_Enqueue_critical() and
_MPCI_Send_request_packet(). It gets rid of the status code translation
tables and instead uses simple bit operations to get the status for a
particular API. This enables translation of status code constants at
compile time. Add _Thread_Wait_get_status() to avoid direct access of
thread internal data structures.
Drop the multiprocessing (MP) dependent callout parameter from the
thread queue extract, dequeue, flush and unblock methods. Merge this
parameter with the lock context into new structure Thread_queue_Context.
This helps to gets rid of the conditionally compiled method call
helpers.
Get rid of the mp_id parameter used for some thread queue methods. Use
THREAD_QUEUE_QUEUE_TO_OBJECT() instead.
Update #2555.
Ensure that kernel and user space system call protoypes are identical.
Parameter was unused.
Newlib provides now a declration for random() in <stdlib.h>. This
confilicts with the define in <rtems/rtems_bsdnet_internal.h>.
The thread queue implementation was heavily reworked to support SMP.
This broke the multiprocessing support of the thread queues. This is
fixed by this patch.
A thread proxy is unblocked due to three reasons
1) timeout,
2) request satisfaction, and
3) extraction.
In case 1) no MPCI message must be sent. This is ensured via the
_Thread_queue_MP_callout_do_nothing() callout set during
_Thread_MP_Allocate_proxy().
In case 2) and 3) an MPCI message must be sent. In case we interrupt
the blocking operation during _Thread_queue_Enqueue_critical(), then
this message must be sent by the blocking thread. For this the new
fields Thread_Proxy_control::thread_queue_callout and
Thread_Proxy_control::thread_queue_id are used.
Delete the individual API MP callout types and use
Thread_queue_MP_callout throughout. This type is only defined in
multiprocessing configurations. Prefix the multiprocessing parameters
with mp_ to ease code review. Multiprocessing specific parameters are
optional due to use of a similar macro pattern. There is no overhead
for non-multiprocessing configurations.
Allow network tasks to run with priority 0 (PRIORITY_PSEUDO_ISR).
