Update #3850
#ifdef HAVE_CONFIG_H
#include "config.h"
#endif
Update #3530.
Update #3533.
Add and use <machine/rtems-bsd-kernel-space.h> and
<machine/rtems-bsd-user-space.h> similar to the libbsd to avoid command
line defines and defines scattered throught the code base.
Simplify cpukit/libnetworking/Makefile.am.
Update #3375.
Close #2877.
Update #2833.
Update #2833.
Apparently 'free' is defined as a macro which takes two arguments and calls
rtems_bsdnet_free. When fixing #2405 I added a missing 'free' but didn't notice
it was non-standard.
Closes #2410.
dhcp_hostname.
Closes #2405.
This allows a suitably configured DHCP server with DDNS to enter
the name into the DNS table making it addressiable via it's host name.
TOD_MILLISECONDS_TO_TICKS().
* libnetworking/rtems/rtems_dhcp.c:
Make format_ip, dhcp_init static.
* libnetworking/nfs/bootp_subr.c:
Make bootp_strdup_realloc static.
* libnetworking/rtems/rtems_dhcp.c (dhcp_init):
Remove unused var "len".
* libnetworking/rtems/rtems_dhcp.c: Remove unused var
"disconnected".
PR 1566/filesystem
* libnetworking/rtems/mkrootfs.c, libnetworking/rtems/mkrootfs.h:
Let rtems_rootfs_append_host_rec take an in_addr_t as first arg.
* libnetworking/rtems/rtems_dhcp.c, libnetworking/nfs/bootp_subr.c:
Reflect changes above.
* libnetworking/nfs/bootp_subr.c: Fixed PR1384. The route set in
the initialise pass is not deleted so an exists error is
returned. Ignore the error. Print the server address as an IP
address not hex digits.
* libnetworking/rtems/rtems_dhcp.c: Fixed
PR1338. Close the socket, handle the returned event flags.
* libnetworking/rtems/rtems_dhcp.c: Removed panic()s. Added
interface for rtems_dhcp_failsafe.
* libnetworking/rtems/rtems_dhcp.h: Added interface for
2008-05-01 Arnout Vandecappelle <arnout@mind.be>
* libnetworking/nfs/bootp_subr: Allow some errors for sosend() and
return on timeout in bootpc_call(). Removed panic()s.
* libnetworking/rtems/rtems_glue.c: Fix the cast for the
SIOCAIFADDR ioctl call.
* libnetworking/rtems/rtems_dhcp_failsafe.c,
libnetworking/rtems/rtems_dhcp_failsafe.h: New.
* libnetworking/Makefile.am, libnetworking/preinstall.am: Added
rtems_dhcp_failsafe.c and rtems_dhcp_failsafe.h files.
