* | cpukit: Remove libnetworking | Vijay Kumar Banerjee | 2021-04-07 | 1 | -47/+0 |
| | | | | Update #3850 | ||||
* | Whitespace removal. | Ralf Corsepius | 2009-11-30 | 1 | -1/+1 |
* | 2008-05-01 Maarten Van Es <maarten@mind.be> | Chris Johns | 2008-05-01 | 1 | -0/+2 |
| | | | | | | | | | | | | | | | | | | * libnetworking/rtems/rtems_dhcp.c: Removed panic()s. Added interface for rtems_dhcp_failsafe. * libnetworking/rtems/rtems_dhcp.h: Added interface for rtems_dhcp_failsafe. 2008-05-01 Arnout Vandecappelle <arnout@mind.be> * libnetworking/nfs/bootp_subr: Allow some errors for sosend() and return on timeout in bootpc_call(). Removed panic()s. * libnetworking/rtems/rtems_glue.c: Fix the cast for the SIOCAIFADDR ioctl call. * libnetworking/rtems/rtems_dhcp_failsafe.c, libnetworking/rtems/rtems_dhcp_failsafe.h: New. * libnetworking/Makefile.am, libnetworking/preinstall.am: Added rtems_dhcp_failsafe.c and rtems_dhcp_failsafe.h files. | ||||
* | The DHCP header. | Chris Johns | 2005-06-30 | 1 | -0/+47 |
