Print out heap statistics via the MALLOC and WKSPACE shell commands.
Move implementation specific parts of message.h and message.inl into new
header file messageimpl.h. The message.h contains now only the
application visible API.
rtems_shell_help static.
* libmisc/shell/main_hexdump.c: Make main_hexdump static.
* libmisc/shell/main_id.c: Make rtems_shell_main_id static.
* libmisc/shell/main_ifconfig.c: Make rtems_shell_main_ifconfig static.
* libmisc/shell/main_ln.c: Make rtems_shell_main_ln static.
* libmisc/shell/main_logoff.c: Make rtems_shell_main_logoff static.
* libmisc/shell/main_ls.c: Make rtems_shell_main_ls static.
* libmisc/shell/main_mallocinfo.c: Include <rtems/libcsupport.h>.
Remove private decls of malloc_info,
rtems_shell_print_unified_work_area_message.
Make rtems_shell_main_malloc_info static.
* libmisc/shell/main_medit.c: Remove private decl of
rtems_shell_main_mdump.
Make rtems_shell_main_medit static.
* libmisc/shell/main_mfill.c: Make rtems_shell_main_mfill static.
* libmisc/shell/main_mkdir.c: Make rtems_shell_main_mkdir static.
* libmisc/shell/main_mknod.c: Make rtems_shell_main_mknod static.
* libmisc/shell/main_mmove.c: Remove private decl of
Make rtems_shell_main_mmove static.
* libmisc/shell/main_mount.c: Make rtems_shell_main_mount static.
* libmisc/shell/main_msdosfmt.c: Make rtems_shell_main_msdos_format
static.
* libmisc/shell/main_mv.c: Include "internal.h".
Make rtems_shell_mv_exit, rtems_shell_main_mv static.
Remove private decls of strmode rtems_shell_main_cp,
rtems_shell_main_rm.
* libmisc/shell/main_mwdump.c: Make rtems_shell_main_mwdump static.
* libmisc/shell/main_netstats.c: Make rtems_shell_main_netstats
static.
* libmisc/shell/main_perioduse.c: Make rtems_shell_main_perioduse
static.
* libmisc/shell/main_pwd.c: Make rtems_shell_main_pwd static.
* libmisc/shell/main_rm.c: Include "internal.h".
Make rtems_shell_rm_exit static.
Remove private decl of strmode.
* libmisc/shell/main_rmdir.c: Make rtems_shell_main_rmdir static.
libmisc/shell/main_route.c: Make rtems_shell_main_route static.
* libmisc/shell/main_setenv.c: Make rtems_shell_main_setenv static.
* libmisc/shell/main_sleep.c: Make rtems_shell_main_sleep static.
* libmisc/shell/main_stackuse.c: Make rtems_shell_main_stackuse static.
* libmisc/shell/main_time.c: Make rtems_shell_main_time static.
* libmisc/shell/main_tty.c: Make rtems_shell_main_tty static.
* libmisc/shell/main_umask.c: Make rtems_shell_main_umask static.
* libmisc/shell/main_unmount.c: Make rtems_shell_main_unmount
static.
* libmisc/shell/main_unsetenv.c: Make rtems_shell_main_unsetenv
static.
* libmisc/shell/main_whoami.c: Make rtems_shell_main_whoami static.
* libmisc/shell/main_wkspaceinfo.c: Make
rtems_shell_main_wkspace_info static.
PR 1924/cpukit
* sapi/include/rtems/config.h: New fields stack_space_size,
unified_work_area, and stack_allocator_avoids_work_space in
rtems_configuration_table.
* sapi/include/confdefs.h: Removed rtems_unified_work_area (this is
now part of the Configuration). Separate work space and stack space
estimate. Added CONFIGURE_TASK_STACK_ALLOCATOR_AVOIDS_WORK_SPACE
configuration option.
* libmisc/shell/main_wkspaceinfo.c, score/src/wkspace.c,
libcsupport/src/malloc_initialize.c: Update due to API changes.
* libmisc/shell/main_mallocinfo.c, libmisc/shell/main_wkspaceinfo.c:
Include information on whether C Program Heap and RTEMS Workspace are
separate.
* libmisc/Makefile.am, libmisc/shell/main_cp.c,
libmisc/shell/main_cpuuse.c, libmisc/shell/main_date.c,
libmisc/shell/main_mallocinfo.c, libmisc/shell/main_netstats.c,
libmisc/shell/main_perioduse.c, libmisc/shell/main_stackuse.c,
libmisc/shell/main_wkspaceinfo.c, libmisc/shell/print_heapinfo.c,
libmisc/shell/shell.c, libmisc/shell/shell.h,
libmisc/shell/shell_makeargs.c, libmisc/shell/shellconfig.c,
libmisc/shell/shellconfig.h, libmisc/shell/write_file.c: Add initial
capability to automatically execute a script from the filesystem. Add
echo command from NetBSD and sleep command.
* libmisc/shell/main_echo.c, libmisc/shell/main_sleep.c,
libmisc/shell/shell_script.c: New files.
* libmisc/Makefile.am, libmisc/shell/main_wkspaceinfo.c,
libmisc/shell/shell.c, libmisc/shell/shellconfig.h: Add route and
ifconfig commands. The code for these was previously in the
networking guide. Disable NFS filesystem mount until that code is in
cpukit.
* libmisc/shell/main_ifconfig.c, libmisc/shell/main_route.c: New files.
* libmisc/Makefile.am: Add new files.
* libmisc/shell/internal.h: Prototype for rtems_shell_print_heap_info()
* libmisc/shell/main_mallocinfo.c: Use rtems_shell_print_heap_info().
* libmisc/shell/shellconfig.h: Add wkspace command.
libmisc/shell/print_heapinfo.c: New files.
