PR 1763/shell
* libmisc/shell/hexdump-conv.c: Remove debug hacks.
PR 1757/filesystem
* libfs/src/rfs/rtems-rfs-block-pos.h,
libfs/src/rfs/rtems-rfs-block.h, libfs/src/rfs/rtems-rfs-file.c,
libfs/src/rfs/rtems-rfs-rtems-file.c: Set the file size in
iop-size when a file is open. Fix lseek to end of file then write
for sizes less than half the file system block size.
* libfs/src/rfs/rtems-rfs-rtems-dev.c,
libfs/src/rfs/rtems-rfs-rtems-dir.c,
libfs/src/rfs/rtems-rfs-rtems.c, libfs/src/rfs/rtems-rfs-rtems.h:
Fix the fstat and fchmod calls due to the change in the iop struct
where pathinfo went away. The node_access field in pathinfo was
overloaded.
* libmisc/shell/dd-args.c, libmisc/shell/dd-conv.c,
libmisc/shell/dd-conv_tab.c, libmisc/shell/dd-misc.c,
libmisc/shell/dd-position.c, libmisc/shell/dd.h,
libmisc/shell/extern-dd.h, libmisc/shell/hexdump-conv.c,
libmisc/shell/hexdump-display.c, libmisc/shell/hexdump-odsyntax.c,
libmisc/shell/hexdump-parse.c, libmisc/shell/hexdump.h,
libmisc/shell/hexsyntax.c, libmisc/shell/main_dd.c,
libmisc/shell/main_hexdump.c: New.
* libmisc/Makefile.am, libmisc/shell/shellconfig.h: Add dd and
hexdump commands.
