Add block_count and media_blocks_per_block to rtems_disk_device. Add
and use rtems_disk_init_phys() and rtems_disk_init_log().
for details.
New functions
o rtems_blkdev_create(), and
o rtems_blkdev_create_partition().
New test libtests/block11.
* libblock/src/blkdev-ops.c: New file.
* libblock/Makefile.am: Reflect change from above.
* libblock/include/rtems/blkdev.h: Declare rtems_blkdev_generic_ops.
* libblock/include/rtems/media.h, libblock/src/media-desc.c,
libblock/src/media-dev-ident.c, libblock/src/media-path.c,
libblock/src/media-server.c, libblock/src/media.c: New files.
* Makefile.am, preinstall.am, libblock/Makefile.am: Reflect changes
above.
* libblock/src/bdpart.c: Removed file.
* libblock/src/bdpart-create.c, libblock/src/bdpart-dump.c,
libblock/src/bdpart-mount.c, libblock/src/bdpart-read.c,
libblock/src/bdpart-register.c, libblock/src/bdpart-sort.c,
libblock/src/bdpart-write.c: New files.
* libblock/include/rtems/bdpart.h: Moved some definitions from bdpart.c.
* libblock/Makefile.am: Update for file changes.
* libblock/Makefile.am: Unconditionall build libblock.
* libblock/Makefile.am: Removed src/show_bdbuf.c.
* libblock/src/show_bdbuf.c: Removed.
* libblock/include/rtems/bdbuf.h, cpukit/libblock/src/bdbuf.c:
Rewritten the bdbuf code. Remove pre-emption disable, score
access, fixed many bugs and increased performance.
* libblock/include/rtems/blkdev.h: Added
RTEMS_BLKDEV_CAPABILITIES block device request. Cleaned up
comments. Added block and user fields to the sg buffer
request. Move to rtems_* namespace.
* libblock/include/rtems/diskdevs.h,
cpukit/libblock/src/diskdevs.c: Move to rtems_* namespace. Add a
capabilities field for drivers. Change rtems_disk_lookup to
rtems_disk_obtain to match the release call. You do not lookup and
release a disk, you obtain and release a disk.
* libblock/include/rtems/ide_part_table.h,
libblock/include/rtems/ramdisk.h, libblock/src/ide_part_table.c:
* libblock/include/rtems/nvdisk.h: Formatting change.
* libblock/src/blkdev.c: Move to rtems_* namespace. Change
rtems_disk_lookup to rtems_disk_obtain
* libblock/src/flashdisk.c: Move to rtems_* namespace. Use the new
support for the block number in the scatter/grather request
struct. This allows non-continuous buffer requests for those
drivers that can support increasing performance.
* libblock/src/nvdisk.c: Move to rtems_* namespace. Removed
warnings. Added better error checking. Fixed some comments.
* libblock/src/ramdisk.c: Move to rtems_* namespace. Added some
trace functions to help debugging upper layers. Use the new
* libfs/src/dosfs/fat.c, libfs/src/dosfs/fat.h: Use new chains
API. Removed temporary hack and changed
set_errno_and_return_minus_one to
rtems_set_errno_and_return_minus_one. Move fat_buf_access from
header and stopped it being inlined. Updated to libblock changes.
* libfs/src/dosfs/fat_fat_operations.c,
libfs/src/dosfs/fat_file.c, libfs/src/dosfs/msdos_create.c,
libfs/src/dosfs/msdos_dir.c, libfs/src/dosfs/msdos_eval.c,
libfs/src/dosfs/msdos_file.c, libfs/src/dosfs/msdos_format.c,
libfs/src/dosfs/msdos_free.c, libfs/src/dosfs/msdos_initsupp.c,
libfs/src/dosfs/msdos_misc.c, libfs/src/dosfs/msdos_mknod.c: Use
new chains API. Removed temporary hack and changed
rtems_set_errno_and_return_minus_one. Updated to libblock changes.
* libmisc/Makefile.am: Add new ls and rm command files.
* libmisc/shell/cmp-ls.c, libmisc/shell/extern-ls.h,
libmisc/shell/filemode.c, libmisc/shell/print-ls.c,
libmisc/shell/pwcache.c, libmisc/shell/utils-ls.c,
libmisc/shell/vis.c, shell/vis.h: New.
* libmisc/shell/extern-cp.h, libmisc/shell/main_cp.c,
libmisc/shell/utils-cp.c: Fixed the usage call bug.
* libmisc/shell/main_blksync.c: Updated to the new block IO ioctl
command.
* libmisc/shell/main_ls.c, libmisc/shell/main_rm.c: Updated to BSD
commands with more features.
* score/src/coremutex.c: Fix the strick order mutex code.
* libmisc/shell/shell.c: Change shell tasks mode to be timeslice
and no ASR.
* sapi/include/confdefs.h: Change ata_driver_task_priority to
rtems_ata_driver_task_priority. Add the new BD buf cache
parameters with defaults.
* score/src/interr.c: Do not return if the CPU halt call returns.
* libblock/include/rtems/nvdisk-sram.h,
libblock/include/rtems/nvdisk.h,
libblock/src/nvdisk-sram.c,
libblock/src/nvdisk.c: New. A Non-volatile memory disk drive.
* Makefile.am, preinstall.am, libblock/Makefile.am: Updated for
the NV disk driver.
* Makefile.am, preinstall.am: Added
libblock/include/rtems/flashdisk.h to the installed header list.
* libblock/Makefile.am: Add flashdisk.c to the files to build.
* libblock/include/rtems/flashdisk.h, libblock/src/flashdisk.c:
New.
fixed synchronization bug between ata.c and bdbuf.c
* libblock/Makefile.am: Don't include preinstall.am.
* libblock/preinstall.am: Remove.
* configure.ac: Add new header guard to cpuopts.h.
* Makefile.am: Add libfs, libblock, ftpd header install rules.
* libfs/Makefile.am, libblock/Makefile.am, ftpd/Makefile.am: Remove
* itron/Makefile.am, libblock/Makefile.am, libcsupport/Makefile.am,
libfs/Makefile.am, libmisc/Makefile.am, posix/Makefile.am,
rtems/Makefile.am, sapi/Makefile.am:
Remove AM_CPPFLAGS += -I$(top_builddir).
* httpd/Makefile.am, itron/Makefile.am, libblock/Makefile.am,
libcsupport/Makefile.am, libfs/Makefile.am, libmisc/Makefile.am,
libnetworking/Makefile.am, librpc/Makefile.am, posix/Makefile.am,
rtems/Makefile.am, sapi/Makefile.am, score/Makefile.am:
Eliminate CFLAGS_OPTIMIZE_V.
* automake/compile.am, httpd/Makefile.am, itron/Makefile.am,
libblock/Makefile.am, libcsupport/Makefile.am, libfs/Makefile.am,
libmisc/Makefile.am, libnetworking/Makefile.am, librpc/Makefile.am,
posix/Makefile.am, rtems/Makefile.am, sapi/Makefile.am,
score/Makefile.am, wrapup/Makefile.am:
Remove build-variant support.
* libblock/Makefile.am: Build libblock for !UNIX only.
* libcsupport/Makefile.am: Build $(TERMIOS_C_FILES) for !UNIX only.
* libblock/Makefile.am: Remove LIBC_DEFINES (Unsupported).
* libfs/Makefile.am: Remove LIBC_DEFINES (Unsupported).
* Makefile.am: Re-add dirstamps to PREINSTALL_FILES.
Add PREINSTALL_FILES to CLEANFILES.
* Makefile.am: Include compile.am, again.
Eliminate C_FILES. Reformat.
* Makefile.am: Add libs to CLEANFILES
Set lib*_g_a_SOURCES = lib*_a_SOURCES.
* Makefile.am: Build libblock$(LIB_VARIANT).a instead of
$(ARCH)/libblock.a.
* Makefile.am: Build library using EXTRA_LIBRARIES and automake rules.
* Makefile.am: Use mkdir_p. Remove dirs from PRE/TMPINSTALL_FILES.
* Makefile.am: Add $(dirstamp) to compilation rules.
* Makefile.am: Add $(dirstamp) to preinstallation rules.
* Makefile.am: Reworked.
* Makefile.am: AM_CPPFLAGS += -I$(top_builddir).
Use AM_CPPFLAGS instead of AM_CFLAGS.
* src/ata.c: Include config.h.
* src/bdbuf.c: Ditto.
* src/blkdev.c: Ditto.
* src/diskdevs.c: Ditto.
* src/ide_part_table.c: Ditto.
* src/ramdisk.c: Ditto.
* configure.ac: Remove (Merged into ../configure.ac).
* Makefile.am: Reflect having merged configure.ac into
../configure.ac.
* ChangeLog, Makefile.am: ATA code depends upon libchip/ide which is
not allowed in the cpukit source code since it must be buildable
independent of any BSP. These files were moved to libchip/ide.
* include/rtems/ata.h, include/rtems/ata_internal.h: Removed.
PR 367/filesystem
* Makefile.am, include/rtems/ide_part_table.h, src/ata.c,
src/ide_part_table.c: Some bugs were still present in the DOSFS
implementation:
- FAT12 did not work properly on Big-Endian machines
- Some synchronization and error handling problems were present
- Some legal codings for EOC were not recognized
* Makefile.am: Eliminate C_O_FILES.
Eliminate SRCS.
* Makefile.am: Merge src/Makefile.am.
* src/Makefile.am: Remove.
* configure.ac: Remove src/Makefile.am
* Makefile.am: Eliminate LIBNAME. Cosmetical cleanups.
Use ../aclocal.
Move from c/src/libblock to c/src/exec/libblock
* configure.ac: Reflect move.
* Makefile.am: Ditto.
* include/Makefile.am: Ditto.
* src/Makefile.am: Ditto.
* Submitted by Victor V. Vengerov <vvv@oktet.ru> and merged
into the RTEMS source.
* ChangeLog, Makefile.am, README, configure.ac, include/Makefile.am,
include/rtems/bdbuf.h, include/rtems/blkdev.h, include/rtems/diskdevs.h,
include/rtems/ramdisk.h, include/rtems/.cvsignore, include/.cvsignore,
src/Makefile.am, src/bdbuf.c, src/blkdev.c, src/diskdevs.c,
src/ramdisk.c, src/.cvsignore, .cvsignore: New files.
