path: root/cpukit/include/dev/i2c/gpio-nxp-pca9535.h (follow)
* Update company nameSebastian Huber2023-05-201-1/+1
| | | | | The embedded brains GmbH & Co. KG is the legal successor of embedded brains GmbH.
* cpukit/include/dev: Change license to BSD-2Joel Sherrill2022-03-251-3/+22
| | | | Updates #3053.
* cpukit/: Scripted embedded brains header file clean upJoel Sherrill2022-03-101-6/+0
| | | | Updates #4625.
* Remove make preinstallChris Johns2018-01-251-0/+123
