* Makefile.am, preinstall.am, libmisc/Makefile.am,
libmisc/shell/shell.c, libmisc/shell/shell.h, telnetd/check_passwd.c,
telnetd/telnetd.c, telnetd/telnetd.h:
Generalized login check.
* libmisc/shell/login.h, libmisc/shell/login_check.c,
libmisc/shell/login_prompt.c: New files.
* libmisc/stackchk/check.c: Changed format for blown stack message.
* libcsupport/src/libio_sockets.c: Removed superfluous cast.
* libnetworking/rtems/ftpfs.h: Documentation.
* Makefile.am, preinstall.am, libcsupport/src/mknod.c,
libcsupport/src/open.c, libcsupport/src/pipe.c, libfs/Makefile.am,
libfs/preinstall.am, libfs/src/imfs/imfs.h,
libfs/src/imfs/imfs_creat.c, libfs/src/imfs/imfs_debug.c,
libfs/src/imfs/imfs_eval.c, libfs/src/imfs/imfs_initsupp.c,
libfs/src/imfs/imfs_mknod.c, libfs/src/imfs/imfs_stat.c,
libfs/src/imfs/memfile.c: Initial commit of POSIX pipe support.
* libfs/src/imfs/imfs_fifo.c, libfs/src/pipe/fifo.c,
libfs/src/pipe/pipe.c, libfs/src/pipe/pipe.h: New files.
* Makefile.am, preinstall.am, libcsupport/Makefile.am,
libcsupport/include/rtems/libcsupport.h,
libcsupport/include/rtems/libio.h, libcsupport/src/base_fs.c,
libcsupport/src/libio_init.c, libcsupport/src/newlibc_exit.c,
libcsupport/src/newlibc_init.c, libcsupport/src/sync.c,
libfs/Makefile.am, libfs/src/imfs/deviceio.c,
sapi/include/confdefs.h: Merge GSOC project code to add simple device
only filesystem (devfs), optionally completely drop out filesystem,
and to clean up disabling newlib reentrancy support. This dropped 17K
from the minimum.exe for sparc/sis and arm/rtl22xx_t now has a 15K
code space.
* libcsupport/src/__usrenv.c, libcsupport/src/newlibc_reent.c,
libfs/src/devfs/devclose.c, libfs/src/devfs/devfs.h,
libfs/src/devfs/devfs_eval.c, libfs/src/devfs/devfs_init.c,
libfs/src/devfs/devfs_mknod.c, libfs/src/devfs/devfs_node_type.c,
libfs/src/devfs/devfs_show.c, libfs/src/devfs/devioctl.c,
libfs/src/devfs/devopen.c, libfs/src/devfs/devread.c,
libfs/src/devfs/devstat.c, libfs/src/devfs/devwrite.c,
libfs/src/imfs/deviceerrno.c: New files.
* libcsupport/src/newlibc.c: Removed.
adapted PPC exception code
* libblock/include/rtems/nvdisk-sram.h,
libblock/include/rtems/nvdisk.h,
libblock/src/nvdisk-sram.c,
libblock/src/nvdisk.c: New. A Non-volatile memory disk drive.
* Makefile.am, preinstall.am, libblock/Makefile.am: Updated for
the NV disk driver.
* Makefile.am, preinstall.am: Added
libblock/include/rtems/flashdisk.h to the installed header list.
* libblock/Makefile.am: Add flashdisk.c to the files to build.
* libblock/include/rtems/flashdisk.h, libblock/src/flashdisk.c:
New.
* Makefile.am: Added libmisc/shell/shellconfig.h to the installed
header list.
* libmisc/shell/shell_cmdset.c: Let the Initial command add occur
in any order rather than before any commands have been added. Also
made the command's strings be copies rather than references.
* sapi/src/ioregisterdriver.c: Return the I/O initialise calls result.
* Makefile.am, configure.ac, posix/Makefile.am, wrapup/Makefile.am:
Move Ada support code that is untestable from the Standard RTEMS Test
Suite into its own directory. All code in score, posix, rtems, and
sapi should be testable by the Standard RTEMS Test Suites. It was
buried under POSIX before so this should be a clearer location
anyway.
* libgnat/.cvsignore, libgnat/Makefile.am, libgnat/ada_intrsupp.c,
libgnat/adasupp.c: New files.
* posix/src/ada_intrsupp.c, posix/src/adasupp.c: Removed.
* configure.ac, Makefile.am: Add libmd.
* Makefile.am, preinstall.am, libmisc/Makefile.am, rtems/Makefile.am,
rtems/include/rtems.h, rtems/include/rtems/rtems/ratemon.h,
rtems/inline/rtems/rtems/ratemon.inl, rtems/src/ratemoncancel.c,
rtems/src/ratemoncreate.c, rtems/src/ratemondelete.c,
rtems/src/ratemonperiod.c, rtems/src/ratemontimeout.c,
score/Makefile.am, score/include/rtems/score/object.h,
score/src/threadhandler.c, wrapup/Makefile.am: Integrate Rate
Monotonic Statistics and Period Usage into Rate Monotonic Manager.
Added the following directives: rtems_rate_monotonic_get_statistics,
rtems_rate_monotonic_reset_statistics,
rtems_rate_montonic_reset_all_statistics,
rtems_rate_montonic_report_statistics, and rtems_object_get_name.
Obsoleted the rtems/rtmonuse.h file as a public interface.
* rtems/src/ratemongetstatistics.c,
rtems/src/ratemonreportstatistics.c, rtems/src/ratemonresetall.c,
rtems/src/ratemonresetstatistics.c, rtems/src/rtemsobjectgetname.c,
score/src/objectgetnameasstring.c: New files.
* libmisc/rtmonuse/rtmonuse.c, libmisc/rtmonuse/rtmonuse.h: Removed.
* Makefile.am: Remove libcsupport/include/sys/cdefs.h.
* Makefile.am: Reflect addition of include/rtems/bsd/sys/queue.h.
* Makefile.am: Add include/rtems/endian.h.
* Makefile.am: Remove ampolish3.
Remove AM_CONDITIONAL(HAS_ITRON).
* configure.ac, Makefile.am, libfs/Makefile.am:
Introduce AM_CONDITIONAL(LIBDOSFS).
* Makefile.am: Add ampolish3.
* Makefile.am: Remove doxygen support having accidentially slipped
into, though yesterday's patch.
* libi2c/Makefile.am, libi2c/Makefile.in, libi2c/libi2c.c,
libi2c/libi2c.h: New files.
* Makefile.am, configure.ac, preinstall.am, wrapup/Makefile.am: added a
simple API/library for i2c devices and drivers for i2c 2-byte eeproms
and a ds1621 temperature sensor; API is documented in libi2c.h
* backward/rtemspppd.h, backward/rtemsdialer.h: New.
* Makefile.am: Add backward/rtemspppd.h, backward/rtemsdialer.h.
* Makefile.am: Add libnetworking/memory.h
* libnetworking/Makefile.am: Remove memory.h
* Makefile.am, preinstall.am: Added a common irq.h
* include/rtems/irq.h: New file.
* configure.ac: Check for newlib with stdint.h/inttypes.h.
* Makefile.am: Conditionally use external stdint.h/inttypes.h for
newlib.
* configure.ac: Add new header guard to cpuopts.h.
* Makefile.am: Add libfs, libblock, ftpd header install rules.
* libfs/Makefile.am, libblock/Makefile.am, ftpd/Makefile.am: Remove
* Makefile.am: Add include/rtems/tar.h.
Merge-in header rules from libmisc/Makefile.am
* libmisc/Makefile.am: Remove header rules.
Remove lib-specific CPPFLAGS.
* configure.ac: Add checks for <tar.h>
* libcsupport/include/rtems/libio.h: Use rtems_id for semaphores.
Use char* for buffer.
* backward/ftpd.h: New.
* Makefile.am: Reflect having added backward/ftpd.h.
PR 756/rtems
* ftpd/ftpd.c, ftpd/ftpd.h, ftpd/Makefile.am: New (relocated from
/c/src/libnetworking/ftpd)
* ftpd/ftd.h: New header guards.
* ftpd/Makefile.am: Install libftd.a, install ftp.h to rtems/ftp.h.
* configure.ac: Add ftpd/Makefile.
* Makefile.am: Add ftpd.
* libcsupport/include/tar.h: New (SUSv3).
* Makefile.am: Integrate newlib-specific headers.
Add libcsupport/include/tar.h.
* libcsupport/Makefile.am: Remove newlib-specific headers.
* acinclude.m4 (RTEMS_CPUOPT): Use AC_DEFINE_UNQUOTED.
* backward/motorola/mc68681.h, backward/motorola/mc68230.h,
backward/zilog/z8536.h, backward/zilog/z8036.h,
backward/zilog/z8030.h: New.
* Makefile.am: Reflect having added new files above.
* backward/confdefs.h: New.
* Makefile.am: Add backward/confdefs.h.
Add conditional DEPRECATED.
* configure.ac: Add --enable-deprecated.
* Makefile.am: Add backward/*.h headers.
* itron/Makefile.am: Install itron.h to $(includedir)/rtems.
* libcsupport/Makefile.am: Install RTEMS specific headers to
* libfs/Makefile.am: Install imfs.h and dosfs.h to
