I am not sure if this is related to this problem, but here is an observation:
All config.sub scripts from rtems' intrastructure packages internally
transform i386-rtems into i386-pc-rtems
newlib-1.8.0-rtems/config.sub i386-rtems --> i386-pc-rtems
egcs-1.0/config.sub i386-rtems ---> i386-pc-rtems
egcs-1.0.1/config.sub i386-rtems ---> i386-pc-rtems
bintutils-2.8.1.0.19/config.sub i386-rtems ---> i386-pc-rtems
gas-98xxxx/config.sub i386-rtems ---> i386-pc-rtems
The only exception is rtems itself:
rtems/config.sub i386-rtems ---> i386-rtems
I am not sure if this influences i386-rtems + c++/posix, but this indicates
that rtems' config.sub script should to be updated.
To fix this, simply copying config.sub e.g. from egcs and removing all
i[3456]-rtems* case statement lines from configure.in should be sufficient.
BTW, from autoconf's point of view i386-pc-rtems is the correct target
conforming autoconf's naming conventions, but using i386-rtems for all
packages (infrastructure and rtems) should make no difference.
subdirectory Makefiles.
used.
individual Makefile.
problem (reported by Eric)
direction. This fixes a problem reported by Steve Evans of Radstone
since he is using glibc2.
enclose.
configuration successfully.
Added code to detect configuring macros and POSIX API at the same time.
There is no macro implementation for the POSIX API.
Avoid generating Makefiles for KA9Q and C++ when they are disabled.
Makefiles would be properly generated.
generating Makefiles where possible.
Added code to make sure make/custom file and bsp directory exist for
configured bsps. This code also accounts for "aliased" BSPs.
eliminated autoconf looking for commands which are unused, and reduce the
number of Makefiles generated.
generate the list of Makefiles in the configure script.
the information in the make/os/XYZ.cfg files using autoconf.
Add monitor test.
Moved files around in list of Makefile's to better support
--disable-tests option.
Added c/src/lib/libbsp/m68k/mvme162/consolex/Makefile to list.
M68040 FPSP was already part of the tree but was not being built.
component which can be loaded on top of the RTEMS source tree.
trip options which allow the RTEMS makefile structure to support
both gcc 2.7.2.2 and gcc 2.8 whenever that is released.
was done based on the 3.6.0 release and had to be autoconf'ed locally.
It is turned on is the bsp enables it and it is not explicitly disabled
via the configure option --disable-tcpip. As many warnings as possible
were removed locally after the code was merged. Only the gen68360
and mvme136 bsps were compiled this way.
The ka9q port and network driver were submitted by Eric Norum
(eric@skatter.USask.Ca).
The network demo programs are not included in the tree at this point.
and regenerated configure.
be resolved.
