* wrapup/Makefile.am: Use install-data-local to install librtemsbsp.a.
Let all-local: depend on $(LIB).
* wrapup/Makefile.am: Remove libmisc.
Posix-BSP-Hacks:
* configure.ac: Add AM_CONDITIONAL(LIBCHIP).
Pass RTEMS_HOST to make/bsp.mak
* Makefile.am: Pass RTEMS_HOST to make/bsp.mak.
* wrapup/Makefile.am: Apply AM_CONDITIONAL(LIBCHIP).
* wrapup/Makefile.am: Pick up ../libchip/rtc/$(ARCH)/librtcio.a and
../libchip/serial/$(ARCH)/libserialio.a.
* configure.ac: Merge wrapup/configure.ac.
Cosmetic cleanups.
* Makefile.am: Add wrapup-SUBDIR.
* wrapup/ChangeLog: Remove.
* wrapup/configure.ac: Remove.
* Makefile.am: Use @RTEMS_BSP_FAMILY@ instead of $(@RTEMS_BSP_FAMILY).
* configure.ac: Remove RTEMS_BSP_ALIAS.
Add RTEMS_CHECK_BSP_CACHE.
Use RTEMS_BSP_FAMILY to detect the bare BSP.
* Makefile.am: Remove setting up bsplibdir.
* Makefile.am: explicitly create $(ARCH) when building $(LIB).
Add bsplib_DATA = $(LIB).
* Makefile.am: Pickup libbsp.a from build directory.
* Makefile.am: Pickup libnetapps.a from build directory.
* Makefile.am: Pickup libmisc.a from build directory.
Remove libxdr.a.
* wrapup/Makefile.am: Remove libxdr.a.
* Per PR233, moved librpc to exec. Ralf will patch after move.
The patches associated with this PR are out of date.
* configure.ac, wrapup/Makefile.am: Modified.
* librpc, librpc/ChangeLog: Removed.
* Makefile.am: Reflect moving libnetworking. Use libnetapps instead.
* configure.ac: Remove CONFIG_SUBIDIRS libblock, libfs.
* Makefile.am: Remove libblock, libfs.
* configure.ac: Special treatment of the bare BSP.
Add RTEMS_BSP_ALIAS. Add HAS_LIBBSP.
* Makefile.am: Append libbsp.a to SRC conditionally.
* DOS filesystem including FAT12, FAT16, and FAT32 support submitted.
* Makefile.am: Modified to reflect addition.
* configure.ac: Remove references to POSIX, ITRON, MULTILIB.
* Makefile.ac: Remove librtems, libposix, libitron. Build
librtemsbsp instead of librtemsall.
* configure.ac: Add AM_CONDITIONAL for enable_multilib,
enable_posix, enable_itron.
* Makefile.am: Compute MULTISUBDIR on-the-fly. Conditionally add
libposix and libitron to SRCS. Apply MULTISUBDIR for picking up
librtems, libposix and libitron.
* Makefile.am: Remove subshell from *.a processing in librtemsall.a
rule.
* ChangeLog: New file.
* Makefile.am: Switch to GNU-canonicalized autoconf macros.
* configure.in: New file.
* .cvsignore: Add aclocal.m4, configure.
* wrapup/Makefile.am: Added libfs.
* wrapup/Makefile.am: Include compile.am.
which is an adaptation of a patch from Ian Lance Taylor plus a few
other changes that should significantly speed up building librtemsall.a.
<corsepiu@faw.uni-ulm.de>.
