* | 2003-11-10 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Ralf Corsepius | 2003-11-11 | 1 | -23/+0 |
| | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | * aclocal/canonical-target-name.m4: Remove. * aclocal/canonicalize-tools.m4: Remove. * aclocal/check-custom-bsp.m4: Remove. * aclocal/check-cxx.m4: Remove. * aclocal/check-itron.m4: Remove. * aclocal/check-multiprocessing.m4: Remove. * aclocal/check-networking.m4: Remove. * aclocal/check-posix.m4: Remove. * aclocal/check-tests.m4: Remove. * aclocal/check-tool.m4: Remove. * aclocal/config-subdirs.m4: Remove. * aclocal/enable-bare.m4: Remove. * aclocal/enable-cxx.m4: Remove. * aclocal/enable-itron.m4: Remove. * aclocal/enable-multiprocessing.m4: Remove. * aclocal/enable-networking.m4: Remove. * aclocal/enable-posix.m4: Remove. * aclocal/enable-rtemsbsp.m4: Remove. * aclocal/enable-tests.m4: Remove. * aclocal/env-rtemsbsp.m4: Remove. * aclocal/gcc-isystem.m4: Remove. * aclocal/gcc-pipe.m4: Remove. * aclocal/gcc-specs.m4: Remove. * aclocal/multilib.m4: Remove. * aclocal/path-ksh.m4: Remove. * aclocal/prog-cc.m4: Remove. * aclocal/prog-cxx.m4: Remove. * aclocal/project-root.m4: Remove. * aclocal/quoting.m4: Remove. * aclocal/rtems-cpu-subdirs.m4: Remove. * aclocal/rtems-flags.m4: Remove. * aclocal/rtems-test-no-pause.m4: Remove. * aclocal/rtems-top.m4: Remove. * aclocal/target.m4: Remove. * aclocal/tool-paths.m4: Remove. * aclocal/version.m4: Remove. * .cvsignore: Remove. * ChangeLog: Remove. * Makefile.am: Remove. * PROBLEMS: Remove. * README: Remove. * configure.ac: Remove. * automake/compile.am: Remove. * automake/host.am: Remove. * automake/leaf.am: Remove. * automake/local.am: Remove. * automake/subdirs.am: Remove. | ||||
* | 2003-08-17 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Ralf Corsepius | 2003-08-18 | 1 | -0/+23 |
* aclocal/bsp-alias.m4: New (Copied from ../../../aclocal). * aclocal/canonical-host.m4: New (Copied from ../../../aclocal). * aclocal/canonicalize-tools.m4: New (Copied from ../../../aclocal). * aclocal/canonical-target-name.m4: New (Copied from ../../../aclocal). * aclocal/check-cpu.m4: New (Copied from ../../../aclocal). * aclocal/check-custom-bsp.m4: New (Copied from ../../../aclocal). * aclocal/check-cxx.m4: New (Copied from ../../../aclocal). * aclocal/check-itron.m4: New (Copied from ../../../aclocal). * aclocal/check-multiprocessing.m4: New (Copied from ../../../aclocal). * aclocal/check-networking.m4: New (Copied from ../../../aclocal). * aclocal/check-posix.m4: New (Copied from ../../../aclocal). * aclocal/check-tool.m4: New (Copied from ../../../aclocal). * aclocal/config-subdirs.m4: New (Copied from ../../../aclocal). * aclocal/enable-bare.m4: New (Copied from ../../../aclocal). * aclocal/enable-cxx.m4: New (Copied from ../../../aclocal). * aclocal/enable-itron.m4: New (Copied from ../../../aclocal). * aclocal/enable-multiprocessing.m4: New (Copied from ../../../aclocal). * aclocal/enable-networking.m4: New (Copied from ../../../aclocal). * aclocal/enable-posix.m4: New (Copied from ../../../aclocal). * aclocal/enable-rtemsbsp.m4: New (Copied from ../../../aclocal). * aclocal/enable-tests.m4: New (Copied from ../../../aclocal). * aclocal/env-rtemsbsp.m4: New (Copied from ../../../aclocal). * aclocal/gcc-isystem.m4: New (Copied from ../../../aclocal). * aclocal/gcc-pipe.m4: New (Copied from ../../../aclocal). * aclocal/gcc-specs.m4: New (Copied from ../../../aclocal). * aclocal/multilib.m4: New (Copied from ../../../aclocal). * aclocal/path-ksh.m4: New (Copied from ../../../aclocal). * aclocal/prog-cc.m4: New (Copied from ../../../aclocal). * aclocal/prog-cxx.m4: New (Copied from ../../../aclocal). * aclocal/project-root.m4: New (Copied from ../../../aclocal). * aclocal/quoting.m4: New (Copied from ../../../aclocal). * aclocal/rtems-cpu-subdirs.m4: New (Copied from ../../../aclocal). * aclocal/rtems-flags.m4: New (Copied from ../../../aclocal). * aclocal/rtems-test-no-pause.m4: New (Copied from ../../../aclocal). * aclocal/rtems-top.m4: New (Copied from ../../../aclocal). * aclocal/target.m4: New (Copied from ../../../aclocal). * aclocal/tool-paths.m4: New (Copied from ../../../aclocal). * aclocal/version.m4: New (Copied from ../../../aclocal). |
