* aclocal/canonical-target-name.m4: Remove.
* aclocal/canonicalize-tools.m4: Remove.
* aclocal/check-custom-bsp.m4: Remove.
* aclocal/check-cxx.m4: Remove.
* aclocal/check-itron.m4: Remove.
* aclocal/check-multiprocessing.m4: Remove.
* aclocal/check-networking.m4: Remove.
* aclocal/check-posix.m4: Remove.
* aclocal/check-tests.m4: Remove.
* aclocal/check-tool.m4: Remove.
* aclocal/config-subdirs.m4: Remove.
* aclocal/enable-bare.m4: Remove.
* aclocal/enable-cxx.m4: Remove.
* aclocal/enable-itron.m4: Remove.
* aclocal/enable-multiprocessing.m4: Remove.
* aclocal/enable-networking.m4: Remove.
* aclocal/enable-posix.m4: Remove.
* aclocal/enable-rtemsbsp.m4: Remove.
* aclocal/enable-tests.m4: Remove.
* aclocal/env-rtemsbsp.m4: Remove.
* aclocal/gcc-isystem.m4: Remove.
* aclocal/gcc-pipe.m4: Remove.
* aclocal/gcc-specs.m4: Remove.
* aclocal/multilib.m4: Remove.
* aclocal/path-ksh.m4: Remove.
* aclocal/prog-cc.m4: Remove.
* aclocal/prog-cxx.m4: Remove.
* aclocal/project-root.m4: Remove.
* aclocal/quoting.m4: Remove.
* aclocal/rtems-cpu-subdirs.m4: Remove.
* aclocal/rtems-flags.m4: Remove.
* aclocal/rtems-test-no-pause.m4: Remove.
* aclocal/rtems-top.m4: Remove.
* aclocal/target.m4: Remove.
* aclocal/tool-paths.m4: Remove.
* aclocal/version.m4: Remove.
* .cvsignore: Remove.
* ChangeLog: Remove.
* Makefile.am: Remove.
* PROBLEMS: Remove.
* README: Remove.
* configure.ac: Remove.
* automake/compile.am: Remove.
* automake/host.am: Remove.
* automake/leaf.am: Remove.
* automake/local.am: Remove.
* automake/subdirs.am: Remove.
* aclocal/rtems-top.m4: Add support for --with-project-root.
Remove RTEMS Version message.
* aclocal/canonical-host.m4: Remove.
* aclocal/canonical-target-name.m4: Merge-in aclocal/canonical-host.m4.
* aclocal/check-multiprocessing.m4: Don't require RTEMS_BSP_ALIAS.
* aclocal/bsp_alias.m4: Remove.
* configure.ac:Remove RTEMS_CHECK_CPU.
* aclocal/check-cpu.m4: Remove.
* aclocal/check-cxx.m4, aclocal/check-itron.m4,
aclocal/check-multiprocessing.m4, aclocal/check-networking.m4,
aclocal/check-posix.m4: AC_REQUIRE RTEMS_CANONICAL_TARGET_CPU instead of
RTEMS_CHECK_CPU.
* aclocal/rtems-top.m4: Add RTEMS_API.
AC_DEFAULT_PREFIX([/opt/rtems-][RTEMS_API]).
* aclocal/check-tests.m4: New (Split out from enable-tests.m4).
* aclocal/enable-tests.m4: Change to support
--enable-tests=no|yes|samples, default is samples.
* aclocal/bsp-alias.m4: New (Copied from ../../../aclocal).
* aclocal/canonical-host.m4: New (Copied from ../../../aclocal).
* aclocal/canonicalize-tools.m4: New (Copied from ../../../aclocal).
* aclocal/canonical-target-name.m4: New (Copied from ../../../aclocal).
* aclocal/check-cpu.m4: New (Copied from ../../../aclocal).
* aclocal/check-custom-bsp.m4: New (Copied from ../../../aclocal).
* aclocal/check-cxx.m4: New (Copied from ../../../aclocal).
* aclocal/check-itron.m4: New (Copied from ../../../aclocal).
* aclocal/check-multiprocessing.m4: New (Copied from ../../../aclocal).
* aclocal/check-networking.m4: New (Copied from ../../../aclocal).
* aclocal/check-posix.m4: New (Copied from ../../../aclocal).
* aclocal/check-tool.m4: New (Copied from ../../../aclocal).
* aclocal/config-subdirs.m4: New (Copied from ../../../aclocal).
* aclocal/enable-bare.m4: New (Copied from ../../../aclocal).
* aclocal/enable-cxx.m4: New (Copied from ../../../aclocal).
* aclocal/enable-itron.m4: New (Copied from ../../../aclocal).
* aclocal/enable-multiprocessing.m4: New (Copied from ../../../aclocal).
* aclocal/enable-networking.m4: New (Copied from ../../../aclocal).
* aclocal/enable-posix.m4: New (Copied from ../../../aclocal).
* aclocal/enable-rtemsbsp.m4: New (Copied from ../../../aclocal).
* aclocal/enable-tests.m4: New (Copied from ../../../aclocal).
* aclocal/env-rtemsbsp.m4: New (Copied from ../../../aclocal).
* aclocal/gcc-isystem.m4: New (Copied from ../../../aclocal).
* aclocal/gcc-pipe.m4: New (Copied from ../../../aclocal).
* aclocal/gcc-specs.m4: New (Copied from ../../../aclocal).
* aclocal/multilib.m4: New (Copied from ../../../aclocal).
* aclocal/path-ksh.m4: New (Copied from ../../../aclocal).
* aclocal/prog-cc.m4: New (Copied from ../../../aclocal).
* aclocal/prog-cxx.m4: New (Copied from ../../../aclocal).
* aclocal/project-root.m4: New (Copied from ../../../aclocal).
* aclocal/quoting.m4: New (Copied from ../../../aclocal).
* aclocal/rtems-cpu-subdirs.m4: New (Copied from ../../../aclocal).
* aclocal/rtems-flags.m4: New (Copied from ../../../aclocal).
* aclocal/rtems-test-no-pause.m4: New (Copied from ../../../aclocal).
* aclocal/rtems-top.m4: New (Copied from ../../../aclocal).
* aclocal/target.m4: New (Copied from ../../../aclocal).
* aclocal/tool-paths.m4: New (Copied from ../../../aclocal).
* aclocal/version.m4: New (Copied from ../../../aclocal).
