Close #3250.
Close #4081.
upgrade to that version.
Close #3387.
line option.
may suppress warnings.
erc32, imx, qoriq, etc.
* cpukit/include
* cpukit/libnetworking
* bsps/include
* bsps/@RTEMS_CPU@/include
order.
Update #3254.
for details.
This reverts commit 621e1c9b74272ff94efec749c6c4a673a7c315e8.
* Makefile.am, Makefile.inc.in, configure.ac, target.cfg.in: Update to
account for movement of .cfg files.
* Makefile.am, configure.ac: Move file generation into Makefile.
* Makefile.inc.in, bsp.cfg.in, configure.ac, target.cfg.in:
Remove itron.
* aclocal/check-itron.m4, aclocal/enable-itron.m4: Remove.
* configure.ac: Remove RDBG.
* configure.ac: SIZE, NM, OBJCOPY.
* target.cfg.in: Remove RTEMS_USE_MACROS.
* Makefile.inc.in: Remove RTEMS_USE_MACROS.
* aclocal/enable-inlines.m4: Removed.
* configure.ac: Remove RTEMS_ENABLE_INLINES.
* configure.ac: Remove RTEMS_CANONICAL_HOST.
* configure.ac: Remove RTEMS_CHECK_CPU.
* aclocal/check-itron.m4: Add m4-quotes.
Require RTEMS_CANONICAL_TARGET_CPU instead of RTEMS_CHECK_CPU.
* configure.ac: Remove RTEMS_PATH_PERL (Unused).
* bsp.mak: Remove support for profile-variant.
* configure.ac: Ditto.
* directory.cfg: Ditto.
* compilers/gcc-target-default.cfg: Ditto.
* make/README: Remove references to profile-variant.
* target.cfg.in: New, copy of c/make/target.cfg.in.
* configure.ac: Add target.cfg.
* Makefile.am: Add target.cfg.
* configure.ac: Only symlink leaf.cfg.
* configure.ac: Remove references to Templates.
Use local AC_CONFIG_LINKS.
* README: Relocated from make/
* lib.cfg: Ditto.
* configure.ac: Unconditionally check for CXX (Hack to bug in
autoconf > 2.54).
* configure.ac: Remove RTEMS_BSP_ALIAS.
Add RTEMS_CHECK_BSP_CACHE.
* Makefile.am: Remove RTEMS_BSP.cache generation.
Remove handling custom/*.cfgs.
Remove handling custom/default.cfg.
* configure.ac: Remove handling of custom/*.cfgs.
Remove auto* generated custom/default.cfg.
* custom/Makefile.am: Remove.
* compilers/Makefile.am: Remove.
* compilers/.cvsignore: Remove.
* Makefile.am: Merge-in former */Makefile.ams.
Add more vars to <BSP>.cache.
* configure.ac: Reflect changes above. Cosmetic fixes.
* compilers/Makefile.am: Remove AUTOMAKE_OPTIONS.
* custom/Makefile.am: Remove AUTOMAKE_OPTIONS.
* configure.in: Remove.
