* score/cpu_asm.c (sh_set_irq_priority): Changed interrupt vector
number range check and handling of interrupt priority regs to
conform SH2 specs.
* sci/sci_termios.c: New file.
* include/sci_termios.h: New file.
* include/Makefile.am (EXTRA_DIST): Added sci_termios.h.
(include_sh_HEADERS): Added sci_termios.h.
* score/ispsh7045.c (isp): Calling an ISR with immediate argument
casued negative sign extension for vector numbers of 128 and
above. This was fixed.
* sci/sci.c: Cleaned initialization of SCI registers; added
necessary setup for new TERMIOS console cooperation
conform SH2 specs.
* mpc8xx/console-generic/console-generic.c:
The printk/printf did not work when loaded by EPPCBUG. They did
work when loaded with the BDM debugger. I suspected EPPBUG
made some nasty things like patching Communication processor
microcode... Anyway, the attached patch:
1) Enables to have printk nearly immediately after boot,
2) Make printf work automagically (I do not know why except I make a
different initialization for printk that should be overwritten by
console init later ?)
I let the default to be using EPPCBUG embedded firmware to boot and
using this printk early enabler code (LOADED_BY_EPPCBUG and
EARLY_CONSOLE) are on.
* mpc6xx/timer/timer.c: Added include of bsp.h and removed
external declaration of BSP_Convert_decrementer() to
correct unresolved reference to this routine.
* mpc8xx/console-generic/console-generic.c: Bug found by Yacine
<elkolli@crf.canon.fr> where the initialization or irq data structure
was incomplete in case a SMC channel was used first and later a SCC one.
* mongoosev/include/mongoose-v.h, mongoosev/vectorisrs/vectorisrs.c,
r46xx/vectorisrs/vectorisrs.c, tx39/vectorisrs/vectorisrs.c,
tx39/include/tx3904.h: All exceptions were given low numbers and thus
can be now be installed and processed in a uniform manner just like interrupts.
Variances between various MIPS ISA levels are not accounted for at this time.
* mongoosev/vectorisrs/Makefile.am, mongoosev/vectorisrs/maxvectors.c,
r46xx/vectorisrs/Makefile.am, r46xx/vectorisrs/maxvectors.c,
tx39/vectorisrs/Makefile.am, tx39/vectorisrs/maxvectors.c,
shared/interrupts/maxvectors.c, shared/interrupts/Makefile.am: Split the
shared maxvectors.c into a variety of CPU model specific versions to simplify
the build process and reduce depdencies. Deleted shared/interrupts/maxvectors.c
and created various CPU model versions.
* clock/clock.S: Move placement of nop.
* Assisted in design and debug by Joel Sherrill <joel@OARcorp.com>.
* mongoosev/duart/mg5uart.c, mongoosev/duart/mg5uart.h,
shared/interrupts/maxvectors.c: Now works. Significant rework
of exceptions and interrupt vectoring to clean things up.
* shared/interrupts/vectorexceptions.c: Removed.
* shared/interrupts/Makefile.am: Reflects above.
* shared/interrupts/vectorexceptions.c: New file to decode
exception code and vector appropriate NON-interrupt exception.
* shared/interrupts/Makefile.am: Modified to reflect above.
* mongoosev/duart/mg5uart.c (mg5uart_enable_interrupts): Honor
the other bits set in the Peripheral Function Interrupt Mask
Register when modifying those enabled for the DUART.
* mongoosev/include/mongoose-v.h (MONGOOSEV_ATOMIC_MASK,
MONGOOSEV_PFICR, MONGOOSEV_PFIMR, mongoosev_set_in_pficr,
mongoosev_clear_in_pficr, mongoosev_set_in_pfimr,
mongoosev_clear_in_pfimr, MONGOOSEV_UART_ALL_IRQ_BITS): New macros.
Modifications made with Gregory Menke <gregory.menke@gsfc.nasa.gov>
as he debugged this BSP using a logic analyzer. In particular,
there was a mistake where the index not offset of registers was
in the header file and the baud rate calculation was incorrect.
* mpc8xx/vectors/.cvsignore, mpc8xx/vectors/Makefile.am,
mpc8xx/vectors/README, mpc8xx/vectors/align_h.S
mpc8xx/vectors/vectors.S: These files were removed in
support of switching the mpc8xx to the use the "new exception
processing model."
* mpc8xx/exceptions/.cvsignore, mpc8xx/exceptions/Makefile.am,
mpc8xx/exceptions/asm_utils.S, mpc8xx/exceptions/raw_exception.c,
mpc8xx/exceptions/raw_exception.h: New files.
* configure.in, mpc6xx/mmu/bat.h, mpc8xx/Makefile.am,
mpc8xx/clock/clock.c,
mpc8xx/console-generic/console-generic.c,
mpc8xx/include/mpc8xx.h, mpc8xx/mmu/mmu.c,
new_exception_processing/cpu.h, shared/include/byteorder.h,
wrapup/Makefile.am: This is conversion of the
mpc8xx CPU to the "new exception processing model."
* Added mongoose-v, mongoose-v/include, and mongoose-v/vectorisrs
directories.
* mongoosev/.cvsignore, mongoosev/Makefile.am, mongoosev/README,
mongoosev/duart/.cvsignore, mongoosev/duart/Makefile.am,
mongoosev/duart/README.mguart, mongoosev/duart/mg5uart.c,
mongoosev/duart/mg5uart.h, mongoosev/duart/mg5uart_reg.c,
mongoosev/include/.cvsignore, mongoosev/include/Makefile.am,
mongoosev/include/mongoose-v.h, mongoosev/vectorisrs/.cvsignore,
mongoosev/vectorisrs/Makefile.am, mongoosev/vectorisrs/vectorisrs.c:
New files.
* Makefile.am, configure.in, shared/interrupts/Makefile.am,
shared/interrupts/maxvectors.c: Added support for mongoosev.
* tx39/vectorisrs/vectorisrs.c: Corrected warning.
* include/Makefile.am: Apply include_*HEADERS instead of H_FILES.
* mpc505/ictrl/Makefile.am, mpc6xx/clock/Makefile.am,
mpc6xx/exceptions/Makefile.am, mpc6xx/mmu/Makefile.am,
mpc8xx/include/Makefile.am, new_exception_processing/Makefile.am,
old_exception_processing/Makefile.am, pc403/ictrl/Makefile.am,
shared/include/Makefile.am, shared/src/Makefile.am:
Apply *_HEADERS instead of *H_FILES.
* shared/src/.cvsignore: Add cache.h.
* clock/Makefile.am: Apply *_HEADERS instead of *H_FILES.
* shared/cache/Makefile.am, tx39/include/Makefile.am:
* m68040/fpsp/Makefile.am, shared/cache/Makefile.am:
* i960ca/Makefile.am, i960ka/Makefile.am, i960rp/Makefile.am:
Remove H_FILES.
* include/Makefile.am, syscall/Makefile.am, cache/Makefile.am:
* cache/.cvsignore: Add cache.h.
* Makefile.am: Apply include_*HEADERS instead of H_FILES.
* .cvsignore: Add cache.h.
* clock/ckinit.c (Install_clock): Modified MTU timer 0 initialization
to generate an interrupt exactly every 1us
* r46xx/vectorisrs/vectorisrs.c (mips_get_cause): Corrected
constraints from general to register.
* tx39/vectorisrs/vectorisrs.c (mips_get_cause): Corrected
* Added r46xx directory.
* Makefile.am, configure.in: Modified to reflect addition of r46xx.
* shared/interrupts/installisrentries.c: Fixed typo.
* r46xx/.cvsignore, r46xx/Makefile.am,
r46xx/vectorisrs/.cvsignore, r46xx/vectorisrs/Makefile.am,
r46xx/vectorisrs/vectorisrs.c: New files.
* /dev/null moved to libmisc.
* Makefile.am, configure.in: Removed null directory.
* include/Makefile.am: Removed null.h.
* include/null.h, null/.cvsignore, null/Makefile.am, null/close.c,
null/cntrl.c, null/init.c, null/open.c, null/read.c, null/write.c:
Removed.
* new_exception_processing/cpu.h, old_exception_processing/cpu.c:
old_exception_processing/cpu.h, Added _CPU_Initialize_vectors().
In particular, spurious vector initialization had to be moved
on old exception processing model.
* tx39/vectorisrs/vectorisrs.c: Modified to have default exception
vector handler. This should be in a separate file so the BSP can
easily override it.
* configure.in: Added new directories.
* shared/interrupts/Makefile.am: Added AM_CPPFLAGS to define TX39
when compiling for a TX3904.
* shared/interrupts/maxvectors.c: Corrected conditional logic.
* tx39/Makefile.am: Added vectorisrs.
* tx39/vectorisrs/Makefile.am, tx39/vectorisrs/vectorisrs.c,
* tx39/vectorisrs/.cvsignore: New files. This decodes the
interrupt pending information on the TX3904 and vectors
an interrupt.
an interrupt.
* shared/.cvsignore, shared/Makefile.am,
shared/cache/.cvsignore, shared/cache/Makefile.am,
shared/cache/cache.c, shared/cache/cache_.h,
shared/interrupts/.cvsignore, shared/interrupts/Makefile.am,
shared/interrupts/installisrentries.c,
shared/interrupts/isr_entries.S,
shared/interrupts/maxvectors.c, tx39/.cvsignore,
tx39/Makefile.am, tx39/include/.cvsignore,
tx39/include/Makefile.am, tx39/include/tx3904.h: New file.
Moved some pieces of interrupt processing from score/cpu to
libcpu/mips since many interrupt servicing characteristics are
CPU model dependent. This patch addresses the number of interrupt
sources and where the ISR prologues are located. The only way to
currently install the ISR prologues requires that the prologues
be installed into RAM.
* shared/src/cache_aligned_malloc.c: Added include of <stdlib.h>
to eliminate warnings.
* displayCpu.c: Added include of <rtems.h> to eliminate warnings.
* cache/Makefile.am: Removed automake warning by introducing a
simple variable.
* cache/cache.h: Fix reference to MC68040 and put in stubs
for missing support routines. The functionality of these
routines needs to be addressed.
* Makefile.am, configure.in: Added support for instruction
cache enabling based on CPU model.
* cache/.cvsignore, cache/Makefile.am, cache/cache.c,
cache/cache_.h: New files.
* shared/src/cache_manager.c
(rtems_cache_invalidate_multiple_instruction_lines): If
CPU_INSTRUCTION_CACHE_ALIGNMENT is defined but 0, then there is
an instruction cache but no notion of line size.
* This is a major reworking of the mips64orion port to use
gcc predefines as much as possible and a big push to multilib
the mips port. The mips64orion port was copied/renamed to mips
to be more like other GNU tools. Alan did most of the technical
work of determining how to map old macro names used by the mips64orion
port to standard compiler macro definitions. Joel did the merge
with CVS magic to keep individual file history and did the BSP
modifications. Details follow:
* Makefile.am: Made clock and timer subdirectories conditional.
* configure.in: Ditto.
* clock/clock.S: Switch from using <idtmon.h> to <asm.h>.
* clock/gettime.S: Switch from using <idtmon.h> to <asm.h>.
* mpc8xx/console-generic/console-generic.c: Avoid use of
BSP definitions and rely on the new routine
mbx8xx_console_get_configuration() to get information. This
routine was formerly incorrectly called
mbx8xx_console_use_maximum_buffer_size().
binding to the exception code.
* configure.in, Makefile.am: Explicitly specify whether an
RTEMS_CPU_MODEL is using old or new exception processing. This
is important because when building multilib, you do not know
the RTEMS_CPU_MODEL. So everything built in a multilib'ed RTEMS
must be independent of the exception model and allow for late
* page.c: Readd deleted comment lines.
* Added full support for MPC505.
* mpc505/ictrl: New directory.
* configure.in, mpc505/Makefile.am: Modified to reflect ictrl addition.
* mpc505/ictrl/.cvsignore, mpc505/ictrl/Makefile.am,
mpc505/ictrl/ictrl.c, mpc505/ictrl/ictrl.h: New files.
* mpc505/timer/timer.c: Use <rtems.h>, not "rtems.h".
* mpc505/vectors/Makefile.am: alignment exception handler now included.
* mpc505/vectors/vectors.S: Now use constants for exception numbers.
* old_exception_processing/ppc_offs.h: New file.
* old_exception_processing/Makefile.am: Account for ppc_offs.h.
* old_exception_processing/cpu.h: Make Nest and Disable levels volatile.
* old_exception_processing/cpu_asm.S: Offsets moved to ppc_offs.h.
* shared/include/cache.h: Improved file header.
